Question about Aprilaire 600 Humidifier
440 Aprilaire Humitifier small solinoid doesn't open
Water to the unit but not past the control valve. I cleaned out hard water sediment but the solinoid doesn't appear to open the valve
    Problem Solver:
  • 7 Answers
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Posted on Jan 14, 2009
There is no water getting to the unit and the water line is ok
Hello, first check the strainer on the inlet side of the solenoid valve, if there is sediment built up clean it and reinstall, if the strainer is clean and you are getting 24 volts to the solenoid valve and it is not allowing water thru replace it.
Mar 31, 2011 | Aprilaire 550 Humidifier
How do I get the water flowing once it becomes clogged with sediment?
Hello, usually the inlet of the solenoid has a strainer that can be removed and cleaned of the sediment. Also, there could be sediment at the saddle valve where in this case you would have to shut off the water supply and clean the valve.
Feb 27, 2011 | Aprilaire 550 Humidifier
Aprilaire 550 making loud noise - sound like not enough water going through pump?
Hello, check to see that the inlet strainer into the solenoid is clean and no sediment has built up in it, also make sure the outlet of the saddle valve is clear and there is no sediment there.
Feb 14, 2011 | Aprilaire 550 Humidifier
760 aprilaire humidifier does not let water to the filter. I have cleaned and checked the lines in and out of solenoid.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your Aprilaire Humidifier is designed to operate in conjunction with your furnace blower motor. Most installers wire a humidifier to operate when the furnace is calling for heat. To determine if your Aprilaire Humidifier is maintaining proper humidity, turn up the heat temperature 5 degrees above the current room temperature on your thermostat and set your humidifier control to call for humidity. The humidifier control is located on the cold air return duct. To set your humidifier control to call for humidity, turn the control dial to the off position and slowly rotate the dial until you hear a “click” on the control. You should also hear a click at the solenoid valve located on your Aprilaire unit. The humidifier control will have a click point at the current relative humidity level in your home. If the current relative humidity is 45% or the outdoor temperature is above 60F, the control will only operate the humidifier in the test mode.
  1. No click at the solenoid valve indicates an electrical problem. Contact your heating and air conditioning dealer to further check the electrical components of your Aprilaire Humidifier.
  1. The click sound at the solenoid valve indicates there is electricity to the solenoid valve. By turning the dial of your humidifier control to a setting above the “click point” you should see water coming out of the drain line within a few minutes which would indicate your humidifier is working.
  1. If the solenoid valve makes a click sound and there is no water draining from the unit, this would indicate the flow of water is being obstructed.
1. To determine if water flow is being obstructed, turn the dial of your humidifier control to the off position. The first location you would want to check for an obstruction would be at the saddle valve located on the water line supplying water to the humidifier. When checking the saddle valve, you want to make sure it is completely open. This can be done by turning the valve all the way to the left. If anything is clogged, it can be dislodged by turning the saddle valve all the way to the right and back to the left. Once this is done, turn the humidifier control dial above the click point and you should see water coming out the drain line.
If water is still not coming out of the drain, check the orifice and in-line strainer to make sure they are not clogged. The orifice is located in the tube on the discharge side of the solenoid valve and the in-line strainer is located on the inlet side of the solenoid valve. You may clear the orifice by inserting a needle through the small opening. Clean the strainer by running it under warm water to dislodge deposits or replace. After clearing and re-installing the orifice and strainer (be sure to double wrench all water connections), turn the humidifier control dial above the click point and you should see water coming out the drain line.
Mar 10, 2010 | Aprilaire Humidifiers
Water runs when furnace is not runnung
not wired properly or stuck solinoid. check for voltage to soliniod if it has voltage then its not wired properly if doesnt have voltage then its a stuck solinoid and the solinoid valve will need to be replaced. you can get from www.aprilaire.com
Dec 03, 2009 | Aprilaire 600 Humidifier
When the system calls for heat My Aprilaire 700 fan turns on, but the solenoid doesn't open up. The indoor humidity is around 35% now, outside temperature was around 35 with relative humidity of 75%. In...
do you hear a clicking at the solinoid? grab the solinoid and turn it on to see if its getting voltage, you should feel it energize. you can turn off the water supply and disconnect the water line from the solinoid. there is a black pre screen inside the inlet if you have a tiny flat heat screwdriver insert it into the inlet and turn it out. clean it and retry. you can also make sure the orifice isnt clogged its located on the outlet side of the soliniod. when you remove you will probably have a stream of water come out of the feed tube thru the orifice, even if it has sat all summer. if water comes out you dont have a clogged orifice. donot try to **** out the orifice if its clogged you will need to get a new one fron www.aprilaire.com . you can verify it clogged by after cleaning the prescreen reconnect the water line inlet and turn on humidifier if water comes thru the solinoid with the outlet feed tube not connected then the orifice is clogged. If you clean the prescreen and the orifice is fine ,still no water then you will need a new solinoid you should also be able to purchase from aprilaire. here is links to the solinoid and orifice
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/299
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/267
hope this helps,
Mac
Nov 07, 2009 | Aprilaire 700 Humidifier
I am not getting any water flow into my Aprilaire Model 600. It is only two years old. How can I troubleshoot this problem?
first make sure you have water going to it. you can shut off the supply disconnect from solinoid then turn on and see if water is coming out. If so if you have a very small flat head screw driver you can try to remove the pre screen inside the inlet of the soliniod. clean it and reinstall. reconnect the water line and energize the valve if you still have no water then either the valve is bad or your not getting voltage to the valve, if its a voltage problem it can get complicated and you would need the tools and some electrical knowledge to follow me.
Oct 30, 2009 | Aprilaire 600 Humidifier
Solenoid on Aprilaire 600
solenoid valves dont just burn up just like that you have a recurring restriction due to bad water.Check the saddle valve at the water heater first then check for postive water flow at inlet to the solenoid valve,if you have water flow the valve is clogged with sediment.
Dec 13, 2008 | Aprilaire 600 Humidifier
I hear to click of the relay, but no water is feeding into the unit
Sounds to me like the solenoid valve is your problem and it is likely stuck due to sediment. I beleive Aprilaire has superceeded all of their old valves to the part number 4040 (used on all models of aprilaire humidifiers) - anyone who services these units regularly likely has one in stock usually $60 - 100.
Nov 11, 2007 | Aprilaire 550 Humidifier
Aprilaire 600 Humidifier Logo
162 people viewed this question
Top Aprilaire Humidifiers Experts
paulcarew
Ken Thomas
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
