Question about Measuring Tools & Sensors
Problem with Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton Gas Powered Pressur pressure washer locks up
    Problem Solver:
  • 5 Answers
Could be the pump is low on oil. They do have oil in the pump itself. Check that.
Posted on Feb 05, 2013
  • 225 Answers
SOURCE: I have a 20 Hp briggs & stratton motor it will
have you checked the oil ?some units have an oil sesor,that if oil level is to low shuts the unit down to stop damage to unit.
Posted on Jun 21, 2009
SOURCE: 123602-0131 BRIGGS & STRATTON ENGINE. NO LOW SPEED
Problem solved by replacing to two mentioned parts. I was told that sometimes it is also necessary to replace the camshaft as some of the plastic teeth on it could also be damaged.
Posted on Oct 11, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 4088 Answers
SOURCE: gasoline leaking into air filter on Briggs &
The float/needle-valve/seat need to be looked at in the carburetor base. The float is not shutting off fuel flow when bowl is at design fuel level. Look for dirt/varnish or anything that interferes with float free movement or preventing the needle valve to close with the seat--usually, just cleaning these parts with spray carburetor cleaner and wiping with a clean cloth will restore operation. Try not to bend anything on the float assembly. Hope this helps!
Posted on Jun 07, 2010
SOURCE: I have a Briggs & stratton 18hp ohv riding
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Posted on Jul 18, 2010
Problem with Briggs & Stratton 2400 PSI 190cc Gas Powered Pressur pressure washer, it locks up
Try disconnecting the pressure hose and work backwards after that like remove the unloader valve and so on. Contact Flowjet cleaning equipment for help over the phone.
Dec 03, 2012 | Briggs & Stratton Measuring Tools &...
Water in oil
sounds like the head gasket is gone once water mixes with the oil
Aug 30, 2012 | Briggs & Stratton Garden
I've got this white powder stuff in my fuel filter
its from using old fuel only use fresh gas 30days or newer
Aug 03, 2012 | Craftsman 2700 PSI,2.3 GPM Briggs &...
How to drain oil from engine
Square socket on the bottom of the engine. I think a 3/8 extension on a ratchet is correct.
Jul 10, 2012 | Craftsman 3000 PSI 27 GPM Briggs ...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Measuring Tools & Sensors Logo
65 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
