Tv no turning on straight away
After turning my dnie 40in tv a clicking sound can be heard comming from the back of the tv which sounds like a relay clicking in and out and it takes about 10 to 15 mins to power up
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The clicking is the relay the set uses--likely bad filter caps in power supply and here is what to look for:
tv no turning on straight away - 12_3_2012_10_15_06_pm.jpg12_3_2012_10_15_22_pm.jpg
Posted on Dec 03, 2012
bluegreenash
  • 661 Answers
SOURCE: no picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Posted on Sep 27, 2007
SOURCE: Samsung TV model CL29Z6 Full flat sreen DNIe Jr - TV don't turn on-
SAMSUNG DNLEJR TV SOUND PROBLEM
Posted on Apr 23, 2009
  • 556 Answers
SOURCE: keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Posted on Aug 07, 2009
SOURCE: samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Posted on Mar 29, 2010
  • 175 Answers
SOURCE: No power to TV
most likley caps in the power supply, let it sit unpluged for a few hours and then ure safe to open and check caps on power board you will see expanded caps replace with exact! and should be good
Posted on Apr 27, 2010
Samsung 40inch TV DNIe DVB SRS TruSurroundXT (model:-LE4OTR73BD (R) s) -: power on but no picture or sound and makes a constant clicking sound.
hi the name is matt the problem i am having is the contrast and brightness constantly change by them self and it is near on impossible to see what you are watching was just wondering if there was anyway to sort that or whether im going to have to get a new tv be a big help thanks
Nov 15, 2012 | Televison & Video
My Tv was working fine for 10yrs then one day i try to turn it on and nothing happen...I heard 2-3 clicks and nothing else. ( NO PICTURE OR AUDIO!!!...This Tv has been great to me over the years, The...
try to look for the power supply area, it is found on where the main plug is connected check if there are busted fuse of shorted parts,, the "clicks that you heard are the relays. relays are loosing out of supply because of a shorted parts like transistor or diodes or sometimes loose connection. Parts description are found in alldatasheet.com for you to know how to test the parts that u suspect
Jul 20, 2011 | RCA P50830BL 50" Rear Projection...
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
No audio or video
the relay is kickking in but a failure in one of the boards is preventing the tv from powering up (protection circut ) and only qualified service centers have access to these parts
Oct 14, 2008 | Toshiba 57H83 57" Rear Projection HDTV
RCA TV
Sounds like one of your relays is faulty or may have a bad solder connection try re soldering the relays.may want to check the solder around the line coils and flyback as well. XL100s have a history of bad solder problems.
Jan 22, 2008 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
