Question about Kenmore Elite 45986 Front Load Washer
F&P ece washer wont spin
Indicater light goes back to deep rinse no matter what setting its put to
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What lights are lit on the display?
Posted on Dec 03, 2012
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 686 Answers
SOURCE: kenmore washer,mod# 110 26292694/wash cycle only
CHANGE THE LID SWITCH
Posted on Apr 09, 2009
SOURCE: I have a Kenmore stackable washer/dryer (apartment
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
Posted on Jan 31, 2010
SOURCE: kenmore washer 417 44252500 does not spin
replaice door swith
Posted on Feb 01, 2010
  • 3 Answers
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
Posted on Apr 02, 2010
My GE HE top load washer quit draining & spinning. I*t went through a wash cycle just fine. It drained & spun for that, but at the end of the rinse cycle it wouldn't. I even tried to put it on
WE HAD THE SAME PROBLEM. ONLY OURS WOULDN'T WORK ON THE "WHITES" CYCLE BUT WOULD WORK ON THE OTHERS. BUT IT WAS JUST A MATTER OF TIME BEFORE THEY WOULD ALL GO & THE REPAIRS WOULD BE $$$. YOU WILL EITHER NEED A REPAIRMAN & YOU'RE LOOKING AT A MINIMUM OF $200........IF YOU'RE LUCKY. DO YOURSELF A FAVOR & GET THE G.E. MODEL #GTWN2800DWW AT HOME DEPOT. LOOK AT IT IN THE STORE BUT BUY IT ON LINE (AS THERE MAY BE A $50 DISCOUNT). THIS WASHER IS WHAT YOU WANT. YOU WON'T BE SORRY.
Jan 11, 2015 | GE Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
Washer does not rinse & spindry after getting submerged in water.
everything needs to be checked from the timer control button to the motor, im guessing it agitated through the wash cycle but wont spin now right? your flood could have damaged any number of items... run through ( with the machine unpluged ) and test the components for continuity and/or resistance.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My bissell deep cleaner wont release water and cleaner into the flow indicater
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Jul 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
