Coleman evcon dgat090bde
Ignition
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: How to install an igniter?
if the heater uses a hot surface igniter its a simple matter of unscrewing the igniter and replacing it with another unit. if it is a spark ignition, the spark wire is a heavy insulated wire that goes to the gap. check out white-rodgers for a replacement. if your furnace uses a purge mode get a purge cycle programmable igniter.
Posted on Nov 15, 2007
  • 70 Answers
SOURCE: i have a coleman/evcon electric
Have you tried to replace pressure switch for the combustion air. If your not sure where to find it if you pull the front panels off follow the flue pipe down to combustion chamber the combustion fan motor is either inside the flue pipe or out side of it not sure on the one you have but you should see two plastic tubes that connect to a barb onto the topside of the fan and one on the bottom they both should go back to the pressure switch. i hope this helps you if you have any more question or if this doesnt fix the problem just reply back to this message . Make sure fan is working when furnace starts up. It should be the first thing that comes on when there is a call for heat
Posted on Jan 21, 2009
  • 2464 Answers
SOURCE: Coleman Evcon BGU12520A won't ignite
check the ignitors condition is it cracked broken burnt out etc , ifn so then it will need replacing , or check the pressure switch is working try jumping it out and see if the ignition glows ,
Posted on Apr 09, 2010
SOURCE: coleman evcon model BGU09516 my unit quit the other night, It goes into preheat mode but does not ignite. I hear it click but no ignition. How hard is it to change the igniter box?
sounds like your not getting gas, is the vavle getting power?
Posted on Oct 29, 2011
Coleman evcon model DGAT070BDF
Open hi temp limit switch or fan limit bad
Apr 01, 2014 | Coleman Propane Forced Air Heater...
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Apr 09, 2010 | Heating & Cooling
We have a Coleman Evcon BW-305150. Last night we
There should be one right above the burner tray. Look at the wiring diagram (pasted on one of the panels) and follow the wires Usually red orange or yellow) to the switch (may look like a rectangle plate with 2 prongs) and jump the switch with a jumper to test.
Feb 26, 2010 | Coleman Propane Forced Air Heater...
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
May 01, 2008 | Heating & Cooling
Nov 12, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
