Question about Sewing Machines
My brother 770 keeps saying safety device has been activated, I have taken the bobbin case and everything off and cleaned it, have also changed the needles, etc. it will sew for a few minutes then messes up again and the thread is all tangled on the backside and the bobbin case is in correctly??? Not sure what could be wrong??
  • Sewing Machines Master
  • 7,365 Answers
Check to see if the top thread has come off the thread take up lever
trying turning the bobbin over the opposite direction
also possible that there is a timing problem with the machine and
it needs to be checked by a repair technican
Posted on Dec 04, 2012
4 Suggested Answers
  • 255 Answers
SOURCE: I have a Brother CS-770.
Hi. It's very likely that the needle is inserted wrong. Take the needle out and make sure that the flat shank of the needle is facing away from you (to the rear of the machine).
Try this and let me know if it helps, ok?
Robbie
Posted on Aug 13, 2010
  • 89 Answers
SOURCE: I have a Bernina Deco
First make sure you have the presser foot lever up when threading the machine.
It you have been doing that then I would check the bobbin area for burs of any kind on the bobbin basket (sometimes you can sand the off). That's about all you can do with the covers on.
Hope this helps
Posted on Mar 24, 2011
  • 1788 Answers
SOURCE: (THIS IS A PREVIOUS POST
Are you saying that you changed the needle? You cannot tell if your needle has a burr on it or not. Because if you did, you may have messed up your timing and need service because it will take special tools and know how to fix it. . Try another needle one more time (make sure that the flat side faces away from you) and different thread. Rethread with your presser foot up, then pull the top thread, it should move smoothly, now lower the presser foot and pull the thread, it should barely move. This should seat the thread in the tension discs. Also, check that you aren't using the wrong size needle for the task at hand.
Posted on Apr 17, 2011
Safety device been activated. baby lock elegant 2
When a safety issue has been activated, it generally means that it should be taken to a technician. In other words, the machine has a fault that prevents it from functioning for the safety of the user.
Dec 26, 2016 | Baby Lock Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
Brother innovis 1200
remove the embroidery unit, change the needle and check again in the bobbin case for tangled thread. Same problem here and this is the way I've fixed it
Aug 04, 2014 | Brother Sewing Machines
Troubleshooting Brother PE 770
Usually this is a tension problem. On mechanical machines, you'd adjust the dial, or possibly even the bobbin tension. But on a computer machine, I don't know how you set the upper tension, sorry to say.
Sometimes it can help to unthread and rethread a machine, and I don't know why it sometimes works, but it's a simple thing to try.
But if the upper tension isn't set correctly for the work being done or if the tension mechanism, however that's handled on a computer machine, isn't working correctly, this is what happens. Bird's nest is a good way to describe it.
Sometimes lint built up in the bobbin case can cause this symptom too, but I'd assume you keep this area clean. One reason I haven't yet invested in a computer machine is because problems like this often don't have such simple solutions as on the mechanical machines.
Jun 30, 2014 | Brother PE-770 Embroidery Machine
The safety device continues to activate on my Brother PE 770
it sounds like the machine needs to be serviced to see that wrong
with the machine
Jan 10, 2013 | Brother PE770 Computerized Sewing Machine
(THIS IS A PREVIOUS POST BUT I AM HAVING THIS SAME PROBLEM. BUT THE TROUBLE SHOOTING THE NEEDLE HASN'T SOLVED THE ISSUE. ANY OTHER ADVICE?) I have a Brother CS-770. My fabric got pulled down into my...
Apr 16, 2011 | Brother Sewing Machines
The safety device has been activated
Turn off the power supply and open the needle plate.
Remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any lint or thread that may have accumulated during use.
If the problem continues, the machine will need to be serviced by a Brother dealer.
Mar 03, 2010 | Brother SE-270D Computerized Sewing...
There's a grinding sound whenever I press the needle position button & the error message "The safety Device have been activated" pops up on the screen
Sounds like the shuttle needs to be cleaned.
Turn off the power and open the needle plate.
Clean the area from lint and any thread that may be trapped.
Mar 01, 2010 | Brother SE-270D Computerized Sewing...
Safety feature activated?
If you can return the machine and get your money back. this machine is nothing but TROUBLE and will continue to have problems.
Nov 07, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
109 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
