SOURCE: GE JVM1440 Spacesaver Microwave
You can fix it without the aid of a repairman. Simply unplug the microwave and remove the outer casing. There should be a few screws around the bottom edge and back panel. Once you have the unit open, look for where the power cord comes in. There should be a circuit board with a fuse mounted to it. This is your input line filter. The fuse should be a 20 amp appliance fuse that you can pick up at any hardware store (Lowe's and Home Depot both carry them). DO NOT op test with the outer casing removed. Potentials of about 14,000 volts are present in the high voltage network of a microwave oven. Close the unit up BEFORE you power it back up. Let me know if this helps.
SOURCE: ge spacesaver microwave ...it is 5 years old and stopped heating
I have an over the oven microwave that blew a magnetron after 4 years. Could be the same thing. It was out of warranty for the free labor, so I took it apart (I'm kind of a geek) and found out the magnetron was gone. Shortening the story: I bought a new magnetron from an online place and replaced it and it works fine. If you have someone replace your magnetron, see if you can get it for free-they have a long warranty on the magnetron ($150 part) and at 5 years, you probably qualify. Rich
SOURCE: Have a GE microwave spacesaver oven/Model
call a pro. these units run at a deadly high voltage. simply not worth your life!
SOURCE: The Charcoal Filter (JX81C) used for non-vented GE
This of course assumes that your oven has the optional Recirculating Charcoal Filter Kit (part # JX81C available here) already installed.
From the owner's manual here:
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: It doesn't heat anything. Could putting metal in
This is usually caused by a "Blown" magnetron, and or the High power Diode And YES, putting metal inside the MW, will cause it to fail.
You need to get a "Quote" for any repair, as the repair may cost nearly as much, as new unit. Also the new unit will have a warranty.
