Question about Mtd Southwest No. 21a - 121r700 Gas Yd/Gdn Cultivator
Replace the recoil starter on a 21A-121R700 yard machines cultivator
3 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
dogsled48195
  • 411 Answers
SOURCE: belt broke on my 12
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Posted on Feb 27, 2011
HOW CAN I REPLACE THE PULL CORD?
remove the three or 4 bolts holding the starter on the motor wind the spring loaded starter backward until you feel real good tension stick a screwdriver through the starter to keep it from unwinding thread the rope through the opening in the starter tie a knot in the end of the rope release the spring that should fix it.
Oct 20, 2015 | Yard Machines Cultivator 21A-121R900
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
My Yard Machine Tiller starter rope will not rewind - it is an MTD engine the model is 21A-121R900. Once I take the cover off I can't get to the rewind mechanism.
you can either drill the rivet out, or inside the shroud there are metal tabs that you can bend out, but be careful as not to break them off. Hope this helped Tim
Feb 27, 2011 | Yard Machines Cultivator
I need a diagram for Yard Machines; garden cultivator; 31cc
Here is a parts breakdown for your machine (found under MTD) with parts listings, diagrams and prices.
http://www.partstree.com/parts/?lc=MTD&mn=21A-121R900
Nov 24, 2010 | Yard Machines Cultivator
Fuel line routing yard machine 31cc cultivator 21A - 120R000
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Apr 29, 2010 | Yard Machines Cultivator
On my tecumseh tiller the rope broke and the setup has rivets instead of screws is there another way to get it off without removing the rivets?
I'm guessing you have a 3.5 or 4HP 4 stroke with the recoil built into the top of the housing? If so, just remove the entire blower housing. It's only 4 bolts. You can then disassemble the recoil assembly to replace the rope.
Mar 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
I have a Tecumseh 10hp HMSK 105. I can't get it to start. It has an electric starter, which won't turn the engine over and the manuel pulley (recoil) won't budge more than 1 or 2 inches. Its like the...
I had a similar problem with an edger and it was due to the blade hitting part of the frame so that the shaft could not turn. With the spark plug disconnected (be careful), try turning the blade with your hand. You can also pull the spark plug and see if the lack of compression makes a difference. I know this isn't a definitive solution but hopefully it will help. Good luck.
Feb 28, 2010 | Yard Machines Tecumseh 148cc Front Tine...
MANUAL FOR A TROY BUILT RIDING LAWN MOWER
Try this site it is called manuals online . Should find what your looking for , Free.
Jul 24, 2009 | Mtd Southwest No. 21a - 121r700 Gas Yd/Gdn...
Mtd Southwest No. 21a - 121r700 Gas Yd/Gdn Cultivator Logo
37 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
