Question about Garden
POLARIS 500 4X4 FRONT WHEELS NOT INGAGING
FRONT DRIVE AXLE TURN NOT WHEELS, PUT NEW ONE ON LIGHTS ALL WORK BUT NOT SPEEDO METER DONT WILL AXLES TURN IF THE MPR IS NOT WORKING.
SOURCE: 4 wheel drive not working
when you engage it in 4 wheel make sure you are getting vacuum to the acuator just pull the hose off and feel to see if there is vacuum if not check all vacuum hoses
Posted on Jan 25, 2009
  • 4 Answers
SOURCE: 4 wheel drive will not engage.
use a hohm meter to check the hub coils . the hub coils should have zero resistance. if the armeture plates shows wear marks on them clean and let dry then paint the back side of them with black tremmclad paint .also make sure that the bearings in the helix are not binding. if they are u can take them apaart and lightly file the slots some so the bearings move freely.
that sloved my problem
Posted on Mar 12, 2009
SOURCE: speedo head display not working 2003 polaris 700 atv sportsman
jump the brown and brown and white on the harness 6 with wires that plugs in to the speedo i had the same problem with my 2000 sportsman
Posted on May 05, 2009
  • 3 Answers
SOURCE: Noise in front axle when I lock my hubs on an 1988 Ford F-150
i would bet you need to replace your locking hubs
Posted on Jul 30, 2009
  • 1509 Answers
SOURCE: 1998 Chevy S10 front axle will not engage when put into 4 wheel
Normal thing that happens as long as onone (worked) on it, is the vacume hose going to the engage sevevo under the battery box has fell of on either end or is brocken on the way there. Then the once or now leaky battery acid ate up this same servo. then the cable going to the front axel breaks sticks falls off or even someone needing one climbed under your truck while parked somewhere to get one to replace their brokeen one now you don't have one then theaxel engage arm or gearset is damaged
Posted on Aug 16, 2009
My fourwheel drive is not working, it makes a grinding noise when pressing on the accelerator and only the back wheels ingage?
do you have locking hubs in the front end? if not it could be your trnsfercase accuater not ingageing all the way.
Dec 14, 2012 | 2000 Jeep Grand Cherokee
1990 4x4 chevy 1500 the 2 drive shafts turn but will not ingage the 4 wheel drive ?I tried the fuses and looks like it has power at the sensors but there is no power at the shifter or no lights is there a...
Your vehicle is an old OBD1 Vehicle.
Forget fuses and sensors,they have no role
Check for vacuum to the front axle vacuum actuator,when in 4 wheel
The console shift indicator bulb, is probably burnt out
Nov 23, 2010 | 1999 Chevrolet Silverado 1500
I want to install a front speedo drive on my 1970 flh harley and im not sure what drive the speedo drive when its on the axle
Your speedometer is driven by the transmission on your '70 model FLH. But, if you want to put a front wheel speedo drive on the bike, first take a look at a bike that has a front wheel speedo drive. You'll notice that the hub right where the axle goes through has a "notch" in it and the speedo drive has a "tab" that goes into the notch. As the wheel turns, the hub turns the speedo drive. This is how it works.
Now, you have two problems, One is that you need a speedo drive that has the spacer built into it so that you can eliminate a spacer on one side of the hub. Next, is the ratio of the speedo drive. The ratio of the speedo drive must match the speedo or the indicated speed will be incorrect. The speedo ratio for your FLH is probably 1:1 since it's a transmission driven speedo.
Good luck
Steve
Aug 08, 2010 | Harley Davidson FLHT Electra Glide...
How do i remove my front wheel on my zzr250
First off you should remove the front caliper, there are two bolts holding that on the lower fork leg, once that is removed that you can loosen the axle and slide the axle out.
Pay close attention to the spacers and the speedo drive when you remove the axle so that you install everything proper when you put it back together.
Also you'll notice that the speedo drive only goes in one way, there are two tangs that need to be lined up on the receiver part of the hub, those have to slip into each other, if not you will damage your speedo drive.
Also before you start make sure you have something to hold the bike up since you will be pulling the front wheel out of it.
Torque the axle nut to 65 ft-lb
Torque the caliper bolts to 24 ft-lb
Apr 20, 2010 | 1993 kawasaki ZZR 250
2003 kia sportage 2l wont engage four wheel drive light comes on but doesnt engage
This is a long/hard one to answer as a few things can cause this. First, check the vacuum lines running from the engine down to the front axles for cracks, and make sure you have vacuum to the axle hub. Second, remove and inspect the front wheel bearings, they should be set to proper preload and there should be no signs of water in the hub. And last if there is water in the hub, that most likely means there is rust on the front axle, and the pitting caused by the rust will not allow vacuum to build up and ingage the four wheel drive. the later requires a new front hub kit $$$.
Feb 21, 2010 | 2002 Kia Sportage
1989 JEEP CHEROKEE when ingage four wheel drive light dose not come on and front axle pops
check to make sure your vacunm motor on front axle is working, getting vacunm and actually moving.
Feb 02, 2010 | 1989 Jeep Cherokee
The speedo on my 1992 xr250r doesnt work, cable and speedo r fine, how do i remove and check the part of the speedo that is mounted on the front wheel
First, remove the lower end of the speedo cable from the speedo gear box on the front axle. Then, lift the front wheel off the ground and remove the wheel. To remove the speedo-drive gear box, unscrew the axle nut that holds it in place. With the speedo-drive removed, inspect the two flanges that fit into the slots on the wheel hub, making sure they haven't gotten bent - or sheared off. When you turn flange on the speedo-drive, it should turn freely and you should be able to see the speedo cable drive-blade spinning. If not, then you will need to replace the whole unit because the worm gear inside has become excessively worn.
Nov 04, 2009 | 1992 Honda XR 250 R
95 dodge 2500 4x4 front axle clicks in 2wd not 4wd when engaged
Do you have automatic locking hubs? Do you need to turn hubs on wheels in order to have 4 wheel drive work? If all you do to get in 4wd is move shifter, then you have automatic locking hubs. The clicking indicates that the hubs are not fully disingaging. To check, block rear wheels, jack front up, and turn tire. the axle should not be turning...if it is, hub is still ingaged....time for new hubs.....if hubs are bad, and you want to save money, you can purchase a set of manual hubs made by (WARN)...its more than half the cost, but you will have to turn hubs to lock and unlock manually. Note...you still need to use the gear selector to put and take out 4wd.
Jul 05, 2009 | 1999 Dodge Ram
Digital speedo jumping randomly up to299kmh not reading correct
The speedo drive sender is very common failure on these bikes following any maintenance involving the front wheel removal (like tire replacement)
The speed sensor is located on front axle on the right side of the wheel
The magnetic rotor gets broken because the drive detent is not properly engaged duing re-assembly.
Fortunately the replacement is relatively inexpensive and reasonably easy to replace if you are careful to engage the drive properly when re-installing wheel. Insert the drive into the wheel before bringing wheel up to forks and inserting axle.
Mar 20, 2009 | 2006 Suzuki SV 650
Ford 4x4 97
check the fluid with your finger, in the front diffriantial if low try to top off if dirty front diff. is bad
Mar 17, 2009 | 1997 Ford F150 Regular Cab
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
