Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Anyone know the shape of the zenith replacement bulb 6912V00006C?
I want to order this Lamp bulb online for my Zenith E44W46LCD tv. However they are asking me to select round or square shape. Can any one confirm the shape before I order this Lamp?
THE LAMP IS SQUARE.
Posted on Jan 16, 2009
Should I replace the bare lamp or the complete housing for the bulb in my Zenith E44W46LCD TV?
Replace it with the complete housing with a bulb inside.The easiest and the safest way to do a replacement of a tv projection lamp.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
How do I find a z52sz80 lamp
It depends where you are located.
In Canada go here: LG/Zenith Lamp Gallery. This link contains all LG Zenith Lamps and Bulbs. You need a 6912V00006C for Z52SZ80 or Z52SZ8D.
easyab
Feb 23, 2011 | Zenith Televison & Video
I replaced my bulb 6912V00006C on my Zenith E44W46LCD and when i plug the TV back in a red light comes on. when i press power a green light blinks for 5 seconds and then goes back to the red light. I don't...
YES, this set is difficult to replace the lamp correctly---it is very likely when you put the cartridge back into the set the two pins on the back did not properly engage inside the set.
Remove lamp and try again, if set was working before and now different problem, the lamp is not properly seated.
If I remember this model, just the bulb is available, you have to take the housing apart and replace bulb--if not perfectly done plug on back with two pins will not engage.
SD TECH
Sep 10, 2010 | Zenith E44W46LCD 44" Rear Projection...
Wont stay on, light with light bulb on it turns red and screen will go blank then tv shuts off completely.
replace the lanp, go online and out in the model number of your tv, when you order make sure you order the entire lamp assebly, on the back of the tv you will find where the lamp is take it out and make sure not to touch the lamp itself when installing the new one
Aug 14, 2010 | Zenith E44W46LCD 44" Rear Projection...
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD tv
TAKE THE FRONT COVER OFF THE PANEL AND REMOVE THE BULB USEING A PHILLIP SCREW DRIVER AND JUST PULL USING THE HANDLE ON THE OUTER COVER OF THE BULB.
Feb 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
THE LAMP
6912V00006C thats you part # go to any online electronics store to for it, such as vancebaldwin.com
Aug 05, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
