Question about Measuring Tools & Sensors
Blue water stains in shower
How to adjust programmable water softener so I don't get blue water stains
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
Blue water stains are not caused by hard or soft water. Blue water or bluish green water is caused by the PH of the water. Low PH can corrosion of plumbing (copper lines) causing bluish green water or water high in alkalinity/PH can cause the same issue. Therefore there is no adjustment on the softener to correct this. I suggest a PH test to see what it is. If the PH is 6.5 or lower a calcite filter is recommended to raise the PH.
RJH2O
Posted on Jan 31, 2013
I have a gainsborough ps1600 shower. Water pressure has dropped. Doesn't help when head is removed. Can still adjust temperature but not speed/power
If the water pressure dropped at a sudden moment, it sounds more like an issue with the water pressure leading into your shower, and not a problem with the shower its self. Try seeing if other water sources in the same area of your shower have the same low water pressure issue.
Stained Glass Leaded Glass St Petersburg FL
Jul 12, 2014 | Home
I replaced old non working culligan system with whirlpool 48000 softner three months ago. In the mornings water from faucet has orange tint until run off for about ten minutes. Water feels soft in the...
Cabinet style water softeners (GE, Whirlpoool, Kenmore, Sears) are very inefficient at removing iron. They are not designed for water with high iron content such as yours. I might suggest setting the hardness level up as high as it can go (100gpg). Indications that water softener resin is getting fouled with iron are exactly as you described. Rusty water the day after a regeneration. You may need an iron filtration system before the softener so all the water softener has to do is remove the hardness.
Here is a link for an iron filtration system that works with air. Very simple, works very well.
http://www.water-right.com/residential/wholeHouseFiltration/impressionIronSulfur.php
RJH2O
Jun 19, 2014 | Whirlpool Water Dispensing & Filtration
I have a delta 1400 series bath/shower and for the life of me, I can't figure out how to get the shower to work. I turn the knob to the left to adjust the temperature. However, I don't have an...
I had the same problem. My building manager showed me that you have to yank the circular portion at the end the of spout where the water comes out downward and the water will be diverted to the showerhead.
Aug 29, 2011 | Delta T13420 Chrome Classic Single Handle...
My Whirlpool duet sport machine occasionally has "stained" laundry. I can't figure out what causes it since I don't wash colors and whites together. The stains appear to be blue. Could this be a fabric...
Make sure you are diluting the fabric softener before putting it into the dispenser drawer. Full strength softener will sometimes stain clothing that's why in the owners manual they always tell you to dilute it first before adding ,plus it last a lot longer and is just as affective... Hope tis helps
Sep 16, 2010 | Washing Machines
I have off-white stains/residue on the metal parts of my shower door. I've tried vinegar and all typse of bathroom cleaners. I cannot remove the stain. It's driving me nuts. Does anyone know what the stain...
white residue could be lime deposits from the minerals in your water,or corrosion if metal is aluminum. try CLR cleaner for lime deposits,use a piece of aluminum foil,'crunched' into a ball & dipped in water to remove corrosion,followed by polishing with an automotive type chrome/metal polish.
Oct 18, 2009 | American Standard 5 ft Sliding Shower Door
My Bosch Classixx dishwasher is using all the salt in one wash.Why and how do I resolve?
In order to rinse dishes and glasses satisfactorily, the dishwasher requires soft water, i.e. containing little or no lime, otherwise water stains will be left behind on crockery and glasses, etc. If the tap water exceeds a certain level of hardness, it must be softened, i.e. decalcified, so that it can be used in the dishwasher. his is achieved by adding a special salt to the water softener inside the dishwasher. The water softener, that is the required amount of salt, is set up according to how hard the tap water is.
Setting up the water softener
Determine the level of hardness of your tap water. Your local water company or service agent can help you with this. Identify setting from the following water hardness table.
Press and hold the B programme button, and set the main switch to ON, before releasing the programme button again.
The indicator lamp for the B button flashes, as does the figure in the numerical display. The latter represents the value that was preset in the factory.
To change the setting:
Press the B programme button.
Every time the button is pressed, the figure increases by one. After reaching 7 the display starts at 0 again.
Set the main switch OFF. The new setting is stored in the appliance’s memory.
Approx. 4 litres of water are required for regenerating the water softening system. The overall water consumption per load can therefore be increased by between 0 and a maximum of 4 litres according to the water hardness setting.
Oct 11, 2009 | Dishwashers
Rust stains on clothing
Cleaned lint out of the dryer internal air ducts.
Replaced the upper and lower drum seals.
Aug 23, 2009 | Frigidaire Dryers
What are the running times for a manual regeneration of a water softner? back wash, conditioning,etc.
This will depend on the make and model of the softener and the estimate of the hardness of the water in your area. The backwash, rinse, soak and fast rinse times can usually be adjusted. Consult the book or call a local company that sells or services water softeners.
Mar 14, 2009 | Home
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
