Question about Dewalt DW005K Rotary Hammer
Drill bit seems to wobble on normal drilling function (over rotates at tip of bit)
Seems like something is bent inside chuck?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Could be a bent bit... if its not its gotta be your chuck or the screw that holds it on
Posted on Dec 09, 2012
2 Suggested Answers
veshapi418
SOURCE: dwoo5 intermitent drilling
coils should changed
Posted on Mar 24, 2012
How can I fix my drill. I was drilling and it froze up on me. You can turn it one way but not the other
Place the drill bit in a bench vise with the whole machine on it together spray the chuck in with good enough wd40 and take a bench hammer and a great plastic hammer , place the angled tip side to the 3 claws of the chuck that are holding the bit and beat slowly and with care the machine from the bit some times switch inbetween the place to beat every claw of the chuck make a little time to do this but do not forget wd40 to spray after and if the machine is beat from the drill spray the whole chuck inside and try to unlock in the most cases it will function again , otherwise there must be an chuck replaced.
Jan 15, 2016 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
Drill bit(masonry) wobble when test it.but it locks but just loose side ways.tnx
Try download once more. If there is any bit loss happened during download; this kind of error display might happen.
Jul 05, 2015 | Drills
How to remove a bent chuck from a Ryobi DP101 bench drill press
look inside the center of the chuck... if the is a bold inside, remove it. then place the short side of a 3/8" allen key into the chuck and tighten the chuck... then smack the allen key from the side with a hammer the same direction as forward rotation...
Oct 25, 2013 | Drills
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
I've just bought my b&d cordless 14v hammer drill but the instructions were just a few pictures. one of them was of an allum key in the chuck and hammer striking it but i dont want to damage the drill....
Hi. Try the drill at slow speed without any drill bit in the chuck. Look closely to see if the chuck wobbles off centre whilst holding the drill firmly. If it does then there is a good chance that the chuck is loose from the body. If it seems ok then next close the chuck (tighten it closed) to see if all the 3 jaws are lining up ok and open it again to see if the jaws retract back down the chuck smoothly. (jaws are the small parts inside the chuck that grip the drill bit) If the chuck it seems loose then you can use a long allan key to tighten it up which is inside the chuck. If the jaws do not operate properly then i would suggest taking the drill back to b&q for them to fix, or replace the tool as it should still be under warranty. Good luck
Jan 22, 2011 | Black & Decker Drills
I have an old Delta D-220 drill press. While the chuck spins true, even at high speed, a drill bit will have a slight wobble towards the end of the bit. I tried many bits so its not a bent bit. Solutions? ...
You are right,but if the wobble is not too big to do drill jobs it can be used.Sometimes drill jobs need to be precise,so the you will need it just aligned.
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or go direct to this link.
Good price and service.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | Delta Woodworking Vintage Delta Dp 220 14"...
The duel head wobbles when locken into
remove any bit,open chuck completely.inside you'll see the chuck mounting screw.is it tight? stripped? bent?
Sep 21, 2009 | Mansfield Drills
Chuck tines on Ryobi Hammer Drill Are Not Engaging Uniformly
home depot replacement chuck i beleive you can also us a keyless chuck. they usually come with instructions. most have a screw at the inside of drill chuck.
tom
Dec 12, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Dewalt DW005K Rotary Hammer Logo
245 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
