Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Bosch slimline dishwasher flooded kitchen
I started my dishwasher,I checked it about twenty minutes later and found my kitchen was flooded from the dishwasher.there was about 4 inches of cold water in the bottom of the machine ,when I opened the door the mch was still running and spraying cold water all over the inside hope somebody can help.Thanks Jim Winstanley.
    Sergeant:
  • 229 Answers
Your debris filter needs to be cleaned. It is found under the dry bar in the bottom of the tub. It looks like a plastic mesh and you can usually remove it to wash it out if not use an old toothbrush etc... this should help.
Posted on Jan 18, 2009
Bosch model SHX68T55UC/02 Completely dead after 2 inch flood in kitchen.
You will need to remove the unit from its installation in the cabinetry. Check the wiring connector located on the rear of the base, near one side. The wire connection must be clean, dry and securely snapped into place. If this connection is burned, distorted or won't allow the plug (special shape) to click securely into place then it should be replaced. Since the unit is totally dead it would appear there is no power reaching the control module, But, you can also confirm that water did not overflow the top of the dishwasher base pan and allow water to enter the pump motors (there are two.) If so these must be thoroughly dried. They may be damaged if power was supplied to a motor with water in the winding and contacts.
Oct 03, 2016 | Bosch Dishwashers
Car starts ok when cold but acts like it is flooded when warm
Is the check engine light on while you're cranking the engine?
Jul 27, 2017 | 1998 Ford Taurus
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Dishwasher backing up
sound like you have a few things going on there.there is a float switch which is located at the front right side of dish washer, make sure this floats freely . also sounds as through your drain line may have become plugged. Ease to fix , remove the line and hard line from the pump with a set of plyers. and remove the debris from the diaphram within the hard line.. before starting this be sure to remove as much water from within the dishwash, easiest way is to use a shop vac.
Jul 26, 2009 | Kenmore 15912 Built-in Dishwasher
Runs about thirty miles then acts like flooded or exhaust plugged
try checking your cadlist convert on your exhusted
Dec 26, 2008 | 1996 Dodge Caravan
Kenmore Elite - Flooded bottom
this is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Nov 19, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwasher keeps running and countdown stalls randomly.
Sounds like The settings have messed up it happened to mine a while back you need to do a hard reset of the dish washer mine was unplugging the thing then plugging back in 30 seconds later then holding the cycle button a few seconds and then power on again. Find your hard reset combination of what your make and model of the dishwasher is I hope this helps.
Jul 16, 2017 | Kenmore 15952 Dishwasher
Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Jan 17, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
190 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
