Question about Garden
Why is my Cub ZTR 50 keep braking belts? I only got 30 minute out of the last one at $40.00 a pop I can't keep going on.
    Sergeant:
    Champion:
  • 278 Answers
Check all the blade spindles for seized bearings. also check the pulley alignment, those issues can cause premature belt failure. Also proper tension can give you consistent long term use.
Posted on Dec 17, 2012
2 Suggested Answers
  • 154 Answers
SOURCE: my cub cadet ztr 50 keeps breaking drive belts the
there can be a rough edge on the drive pulleys that cause the belt to get cut
Posted on Aug 07, 2009
Our dixon ztr 50 inch mower deck belts keeps popping off.Why?
The only thing that causes this is misaligned pulleys, use a straight edge and check that. Also make sure none of the pulleys have excessive up and down side to side play due to a failed bearing.
Aug 29, 2017 | Garden
Why would my belt on my cub cadet 1046 mower keep popping off?
Did you put all the belt keepers back on? I find a lot of DIYers usually leave one off thinking it is not important.
Jun 30, 2015 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
My cub cadet ztr 50 keeps breaking drive belts the 1st after 130 hours and now after 4 hours
Aug 06, 2009 | Garden
Problem with left side hydrostatic transmission
This is a well documented problem with cub cadet ZT transmissions. They tend to go bad after 200 hours of use. Sometimes having the dealer change the transmission oil will help (they need to remove the transmissions to do this!). Most times, the transmission is gone & must be replaced ($800-$900).
Sound to me like a design defect. My ZT-50 lasted only 4 years. Needless to say, the replacement was not a cub cadet.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 | Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
