Question about Lionel The Polar Express Train Set
Put smoke fluid in the wrong place on Lionel polar express train, got all the controls wet on main engine
  • 40 Answers
Remove the shell. Soak up as much as you can. Leave out to dry or use a hair dryer on low until controls are dry.
Posted on Dec 04, 2013
  • Traindoc Jun 16, 2014
    Remove the shell, turn the motor upside down and put it on a towel to soak up the smoke fluid. The smoke fluid won't dry because it is not water based but is an oil. If the engine doesn't run after doing this you'll have to take it to a Lionel Service Center for repair (usually replacement of oil soaked motor or switches).
SOURCE: My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Posted on Dec 08, 2008
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Posted on Dec 25, 2010
  • 34 Answers
SOURCE: I'am looking to sell my Polar express lionel
Please go to the Lionel WebSite and type:
73-1960-250 in to search. This is a PDF file for the Polar Express which was released by Lionel in 5/05. You can also go directly to: http://www.lionel.com/media/servicedocuments/73-1960-250.pdf
Posted on Oct 05, 2011
Unit will not smoke, this is the second time I ran train.
have you added the correct amount of smoke oil to engine ?
part number 6-37841 lionel
Dec 29, 2015 | Lionel 31960 The Polar Express O Gauge...
Led blinks when train put on track
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Feb 10, 2015 | Lionel The Polar Express Train Set
When I my brand new Lionel train on the track, the red light goes out. Is there a short in the loco?? This isa the Polar Express 73-0218-250 model Xmas is tomorrow!!
I am assuming that the throttle is off when you put the train on the track. If off, then you are correct that there is an internal short in the engine. You might try disassembling the unit and looking for a pinched wire specifically from a roller(s) (center rail pickup). You might also check for a short between a pickup roller and a wheel with a VOM. Make sure the wheel is not the one with the neoprene belt.
Dec 25, 2014 | Lionel The Polar Express Train Set
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
Lionel polar express train is stopping on the track, then becomes disabled
Replace all the batteries, then keep the remote close to the
train. if it's too far away, it will shut down.
Jan 06, 2013 | Lionel The Polar Express Train Set
How can I fix smoke problem on polar express
Most Lionel engines have a small slider switch which can turn off the smoke generator. Check to see that the switch is in the ON position. Check the engine manual (available from Lionel's website) for the location of the switch.
Also, if the smoke generator is always on and no fluid had been used in the generator, it will eventually burn out. Replacement smoke generators are available from Lionel.
Jan 05, 2012 | Lionel The Polar Express Train Set
Polar Express locomotive will not smoke with smoke fluid in stack and smoke switch on.
You may have to check if there is power to the heating element. You can also check to see if there is too much fluid. You can also put the engine in neutral and tap the chimney hole a few time to kind of "prime" the smoke unit.
Mar 16, 2011 | Lionel Polar Express Train Set
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Lionel The Polar Express Train Set Logo
258 people viewed this question
Top Lionel Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
