What does a 130 code mean on my fisher paykel washing machine?
I am getting a code of 130 on the readout display. I have tried unplugging the machine as I was instructed before, but the code returns momentarily. Can you tell me what fault code indicates?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What lights are lit on the display?
Posted on Dec 03, 2012
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 713 Answers
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
Posted on May 27, 2010
  • 28 Answers
SOURCE: Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Posted on Jun 21, 2008
  • 41 Answers
SOURCE: My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Posted on Jan 31, 2010
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Posted on Sep 30, 2009
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Intuitive ECO Model IW811 display error codes 240 and 130. what does this mean?
The fault codes 130 and 240 are pertaining to a Rotor Position Sensor problem. It is the part located wedged into the motor stator and it's sole function is the detection of motor functions particularly the rotor as the name suggests. The problem can be a simple loose wire harness or a damaged Rotor Position Sensor.
Unplug the machine. Tape the lid closed then lay the machine's front on a padded floor. Remove the single bolt holding the "plate-like" rotor to the shaft to access the Rotor Position Sensor. Once the rotor is off, check the contacts on the Rotor Position Sensor end of the wire harness to see if any have been damaged. Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Position Sensor harness. Consider replacing the Rotor Position Sensor if no issue is found with the harness and the connectors.
Jul 18, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Code 130 is displayed and will not run even after unplugging for 2 minutes
Code 130 indicates Rotor Position Sensor (RPS) fault.
RPS is just underneath the machine. It can be accessed by removing the plastic cover (the outer part of the motor) by one bolt. Then remove cover to access the windings of the motor. Undo the four bolts, drop the windings off the machine; you now have two parts of the motor off and the RPS can be accessed. Remove it and clean it up.
Reset the machine again by unplugging for 2 mins. If it doesn't work, then it means that the sensor needs to be replaced.
I hope this information helps you.. Good luck! :)
Jun 07, 2011 | Fisher and Paykel WL26CW1 Top Load Washer
Jan 24, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher and paykel washing machine
Unfortunately, it means get a technician to your home. Something is wrong with the "board". I had the same problem
Sep 01, 2008 | Fisher Paykel Eco IWL16
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
717 people viewed this question
Top Washing Machines Experts
