How can i change bearings on a whirlpool aquasteam washing machine
My washer have been making hell of a racket an ive been told its the bearings so im wondering does anybody know how to change the bearings, its a whirlpool aquasteam 6th sense
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 03, 2012
5 Suggested Answers
  • 6277 Answers
SOURCE: My whirlpool 6th sense washing
Whirlpool's 'FE' stands for 'Filter Error'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 19, 2011
muttandjeff
  • 359 Answers
SOURCE: Washer makes loud rattling noise when spinning
first check to make is to be sure machine is level using a 2ft level ck level side to side and front to rear see if level if not adjust either by adjusting level legs on bottom of machine or using wooden door shims available @ building supply store , if you don't have level use two small clear water glasses with a exact amount of water in each put a line on each glass measure with rule and make sure line is in exactly same spot on each glass fill to line and place one on rear of machine and one on front level till lines match then repeat process side to side
Posted on Jan 11, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
SOURCE: hi, my whirlpool aquasteam 6th
hi i have whirlpool aquasteam AWO/D AS148 with fault F05 what do i need to do and can i repair it myself??
thanls
Posted on Sep 21, 2011
Whirlpool aquasteam suddenly dead, no lights at all,as if plug pulled halfway through wash. Tested plug, socket fuses all fine.
Check the fuse (circuit breaker) at the main box. Most Washers are on a separate circuit and thus if the circuit breaker opens, there will be no power to the washer.
Feb 11, 2018 | Whirlpool Washing Machines
I have whirlpool aquasteam 6th sense fromtliad washer 9760. It wont drain the water
Probably you have a clogged water pump clean it if not clogged then you have to know how to check if you have voltage to it, do so if you have 120 volts then it's your water pump http://www.appliancepartspros.com/whirlpool-washer-drain-pump-280187-ap3953640.html
Apr 29, 2016 | Whirlpool Washing Machines
Parts diagram
bearing kit try e spares.com
Oct 03, 2013 | Speed Queen CTS90AWN Front Load Washer
My indesit washer dryer makes a hell of a racket on the final spin. Tje bearings are fine but it looks like the shocks dont do anything. I can move the whole drum forwards and backwards about 2...
yes
it is called an air dampener and controls the drum movement to stop unbalance when starting
they come in a pack of 4 and average price is around $90.00aud
Dec 14, 2017 | Washing Machines
Hi, my whirlpool aquasteam 6th sense washing machine has a fault, its flashing a red symbol on the screen . . what is this?
The F05 fault is nothing to do with what soaps you use.. Its a little red wire located at the front bottom centre of your aquasteam washer that has come lose or detached. A task to get to it but pretty easy and dodgey repair men would have your pants down for such a simple thing
Dec 11, 2010 | Whirlpool Washing Machines
My washer is making a grinding, metalic noise when the agitator is supposed to be moving. Water enters and drains fine. The agitator moves very little and makes a great racket. Help!
Could be the belt or the bearing or both...
You need to remove the belt and test if agitator moves easy by hand, then it means bearing is OK
Apr 16, 2010 | Whirlpool Washing Machines
Washer gets badly out of balance and makes a racket and moves
The most likely cause is a bad or broken balancing spring and or shock absorber connecting the drum to the washing machine housing.
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine makes noisy squeal when pumping out water
i turn the dryer on it goes for a few minuts and then it fuses all the power points
Apr 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Aquarius WF 320 Noisy Drum
Could be your bearings for sure. And if you have been using the machine while the racket continued......you could be ruining you axle as well. So make sure your axle is fine before you change your bearings.......
Oct 26, 2006 | Hotpoint Aquarius WF220 Front Load Washer
Washing Machines Logo
292 people viewed this question
Top Washing Machines Experts
