Question about Toshiba 2060 Copier
Toshiba 2060 jams (accordion/fans the paper) at the fuser unit. Torn Paper now stuck next to the roller/drum and now jams every time. How do I remove the torn bits of paper to keep it from jamming?
  • 117 Answers
Sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Posted on Mar 24, 2009
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
Asked me a paper was jam
You didnt wrote where it is the paper jam.
Here are few common jams:
  1. if the paper jams in fuser unit, do/check next:clean the paper delivery rollers ( when you open left door its two roller on axis beneath the drum ), check the sensor flapper beneath the drum unit if its worn out you need to replace it, does the paper comes out like bent in the roll? open fresh pack of the paper and try again it could be moisture fault.
  2. the paper stucks in pickup section, clean the paper pickup, feed and separation roller, to do that remove paper drawer and you will be able to see the rollers on left inner side.Open the lower leftside door and check the paper senzor in the middle.You can apply some wd40 on spring of flapper or on left side bushing.
  3. dadf jam, check for any paper leftovers and clean the paper pickup and feed rollers
Hope that helps!
Sep 07, 2010 | Canon iR 2016i Black and White Copier
Hello, my Brother MFC-7420 started a few months ago to wrinkle the sheets, like an accordion. a technician said is the fusor and another technician says it is the drum, which one is right?
The fuser is most likely your candidate. A drum transfers the image onto the paper, but the transfer is made with an electric charge. The fuser applies heat and pressure to bond the toner to the paper.
If the fuser rollers are worn or there's heavy buildup on them, they will cause the paper to skew, crease and/or jam.
In the case of the paper bunching up and looking like an 'accordion', if this happens at the entrance guide to the fuser assembly, you're pretty much guaranteed the fuser's either jammed or defective.
Sep 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper getting stuck in the rear of Brother 2820 fax machine...
Hi, There are many reasons for jams in the exit of machines and I will list the most common for you damp paper will curl as soon as it hits the fuser rollers... the fix - change paper the fuser rollers are worn (teflon coating is no longer able to deflect toner) and jams are occurring.... the fix - replace the fuser unit
Jun 09, 2009 | Brother IntelliFax-2820 Laser Fax
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
Paper always get jam at the fuser
This is a common problem and does need a service engineer, the four fuser exit roller assemblies need replacing as they have been upgraded to address this problem.
FYI the parts cost approx
Mar 24, 2009 | Brother IntelliFax-2820 Laser Fax
Paper Jam
If you are getting a lot of jams in the fuser then there is a problem in the fuser unit !
Is it jamming like an accordion? if Yes, then the problem is w/ the little fingers in the fuser, they are worn and need to be replaced. The rollers in the fuser should be shiny and smooth if not they ca also cause jams.
What black thingy are we talking about and where? if it's the fuser rollers ( where the paper exits and gets hot then try cleaning w/reg soap & water rag then wipe off.
Nov 17, 2008 | Sharp AR-153E Copier
Toshiba 2060 Paper Jam at the fuser
I would have to say that you are missing the fuser drive. I would remove the fusing unit and look to see if you are missing any gears or any missing teeth from a gear or just missing a gear...
Jun 18, 2008 | Toshiba 2060 Copier
Paper Jam
1st, you need to find out exactly where the paper is getting stuck.
Is the paper stopping just as it gets to the rollers, or
stops when it goes through the rollers and are getting stuck on the little fuser claws?
If the paper is stopping right when it gets to the rollers, then there is a problem with the fuser drive or drive gears.
This you would probably need to place a service call to have repaired.
If the paper is getting stuck in the claws, then make sure that the claws are not stuck down. All claws should be up against the rollers, both upper and lower claws.
Sometimes they get stuck down or the spring gets knocked off.
Other than that, as long as both upper and lower fuser rollers are in good condition, paper should pass through.
If you have any other questions, feel free to repost.
Good luck.
If I have helped answer your question, please remember to post a rating.
Mac =)
Mar 18, 2008 | Toshiba 2060 Copier
223 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
