Question about Danby 22 in. DDW396 Free-standing Dishwasher
Danby DDW396: pump leaks when in use.
The pump leaks and overflows into the bottom of dishwasher. I believe the seal between pump and motor is bad. Took off motor but a piece of the pump is attached. How do I get that apart without breaking it?
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
I been replaced My radiator 2 times and i saw a leak ,so any advice forma this
It could be the overflow reservoir is overfilled, a defective radiator cap or the bearing seal hole on the bottom of the water pump is leaking(bad water pump). If not these things, place a large piece of cardboard under engine compartment, make a location reference mark on the cardboard and you may find your leak.
Feb 16, 2015 | Cars & Trucks
Bosch shu8805 (2002 model)
HI,
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 18, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Danby dishwasher seems to be leaking on front left side - how to fix
http://www.retrevo.com/support/Danby-DDW396W-Dishwashers-manual/id/886dj685/t/2/
Above is a user manual, below is a self help dishwasher repair how to.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
You really must get a service manual. But if you cannot find one, simply open up the inspection hatch, and look for the source of the leak, usually around the Pump, filters etc, often a fitting has come loose... as related locate and repair your leak.
Jul 12, 2010 | Danby 22 in. DDW396 Free-standing...
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Broken glass in tub and now dishwasher leaks from pump. It is hard to see exactly where the water is coming from but it appears to be above the pump.
Hello- By pump do you mean motor pump, or drain pump? Drain pump has a small seal that can leak but rarely does. Motor has a seal that can leak, causing motor to fail eventually. This is confirmed by a small amount of water/deposits on lowest point of motor. This leak is unrelated to glass pieces in tub. Motors with this leak get louder as bearing fails, and eventually lock up. Let me know if this info helps- have more if needed- Thanks- Ed
Mar 12, 2010 | Dishwashers
Lately when i run my dishwasher, it leaks from the front but i can't seem to pinpoint where the leak is coming from
If the water is not overflowing the bottom due to a bad float/switch, check the perimeter door seals for any damage. There is usually no seal at the bottom of the door. Check around the pump and associated hoses for any signs of leakage. Make sure that the latch is holding the door tightly while operating.
Jan 30, 2010 | Dishwashers
Danby countertop dishwasher DDW396W pump size???????????
Best place for Danby parts is Sears Parts department online. Type in your model number DDW396W. They have diagrams and assessable and parts for just about everything you need.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=DDW396W&pop=flush
Just click on the sub components area that you need!
-Dustin
Jun 25, 2009 | Danby 22 in. DDW396 Free-standing...
Water does not drain from the bottom. I understand that a small amount is normal, however, this is not a small amount. Thanks for your help.
It worked for me .I have a danby countertop dishwasher.
I took off the metal top
I looked under on the left side to find the pump
I took both hoses off the pump and took off the little fan.
i took off the little metal bracket behing the little fan. and unscrewed the little pump to take it out.
the little metal piece that the fan was on wouldn't even move.So i sprayed it down with wd and it started moveing again then a screw fell out.so i found where it went(inside the motor which the fan and metal piece move) got the tweezers and replced it. oiled it some more and put it all back together. Perfect.
May 24, 2009 | Danby 22 in. DDW396 Free-standing...
Leaks from handle
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 27, 2009 | Danby DDW1805W Designer Series...
Danby 22 in. DDW396 Free-standing Dishwasher Logo
335 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
