Question about Sony DVP-FX750 Portable DVD Player
My daughter droped her dvd player now the screen is all white but the sounds still works. Can we get a new screen are is it better to get a new player.
Everything still works fine just the picture is all white with some blue lines in it.
    Top Expert:
  • Sony Master
  • 14,553 Answers
Likely damage to either the main board or the hinge unit.
Posted on Dec 03, 2012
5 Suggested Answers
shajanrs
  • 890 Answers
SOURCE: I have a Sony BDP300
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Posted on Feb 06, 2011
tthekraut
  • 374 Answers
SOURCE: I just purchased a Sony
Try to go under the settings in the dvd player. Be sure all the setting are set up according to your TV.
Sometimes if you dont have it set to N. American standards it can output like that. Be sure its set to "NTSC" if you live in N. America or Japan. If you live in Europe be sure its set to "PAL".
Let me know If this is not a issue in comments and I will help you further but I think this is it.
Posted on Mar 18, 2010
omoadeley
  • 84 Answers
SOURCE: I am hooking a dvd player to our new flat
at the side of the flat screen there is tv in so check the cord and make sure it goes directly to tv in ok.
Posted on Jun 06, 2010
SOURCE: cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
Posted on Jan 02, 2012
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
No picture on one screen
Sounds like the screen went bad/went out. Lcd's going all white signal a need for a new panel. Sorrry, the screen needs to be replaced. It's beyond repair. needs new screen.
May 14, 2009 | TruTech PVS12701 Portable DVD Player
Broken lcd screen - PET704
You will find it is better to buy a new player. The cost of the part and repair will be about the same or more. You can still use the player with the a/v output to another monitor or television. Just use the supplied cables or purchase some for the connections. I hope this information helps you with your problem.
Apr 23, 2009 | Philips PET710 Portable DVD Player
Screen is white
Hi
maybe you have defective Flrx ribbon wire or the LCD is the defect.
Thanks!
Dec 14, 2008 | Haier Portable DVD Player PDVD7
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
White line on screen
Usually a white line straight across the screen indicates that the LCD screen has a bad row. There's not much you can do about it I'm afraid.
If you're mechanically capable, you can go to e-bay and pick up a non-working unit (for parts) and replace the screen on your working unit. I guess it depends on the cost of the unit. You might just be better off using it as is.
Mar 27, 2008 | SanDisk Sansa e260 MP3 Player
Portable DVD showing blue screen
i have the same dvd player the pink 1 i lent on a button and it went into black and white i have tried everything and can't seem to get it back into colour again, ive tried pressing all the buttons and nothing seems to work or come up with any black and white/ colour options :(
Mar 04, 2008 | Televison & Video
Dvd player screen
You need to order a new screen for the dvd player.
Jan 21, 2008 | Durabrand PDV-705 Portable DVD Player
Sony DVP-FX750 Portable DVD Player Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
