Question about Horizon Elite 2.1T Treadmill Walking Belt
HORIZON ELITE 2.1T TREADMILL - Horizon Elite 2.1T Treadmill Walking Belt
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Posted on May 23, 2010
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
SOURCE: change speedometer readin on elite 507 treadmill from mph to kph
I know this is an old thread, but if you are still trying to change between mph and km, then follow these instructions.
The setting is changed by a switch on the console circuit board. Unplug the power cable. You will need a medium philips screwdriver. The console is fixed to the frame with 4 screws, climb under the console and remove 2 screws from the top and 2 screws from the bottom. Get back up and lift the console up slightly making sure you do not dislodge any cables from either the left or right-hand side of the console. Look under the console from the left-hand side, in the middle of the circuit board you will see a small slide switch (silver casing with black slider), slide it to the other position. You will see next to the switch the letters mph and kpmh. gently reseat the console, put the 4 screws back in, the console should now display the speed in kmph when you plug it back in and turn it on.
All the best
Posted on Feb 24, 2011
Ticking sound on horizon t101 treadmill
If you wish to get some details about treadmill repair; visit the site linked here. in the search tab put the world "ticking" and search.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Horizon Exercise & Fitness
Troubleshooting manual for elite 5.3t treadmill
Have you checked out the manual that came with unit? Contacted support at manufacturer web site?
Nov 13, 2015 | Horizon Elite 5.3t Regular Treadmill...
Can you replace the treadmill belt.yourself for an horizon elite t5000
Is the belt damaged to the point that it needs to be replaced? You can adjust the machine to tighten up a loose belt. Instructions on how to do this are in the owner's manual.
Feb 04, 2015 | Horizon Exercise & Fitness
Do treadmills need calibrating
Some do mostly for incline motor
Jul 15, 2014 | Horizon Elite T5000 Treadmill
I need a owners manual for my cardio zone treadmill we bought it and did not get a manual
You have a Horizon Elite Treadmill.
Owners manuals can be found at
http://www.horizonfitness.com
look under customer support, archives/manuals
Dec 15, 2010 | Elite Exercise & Fitness
Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
Apr 18, 2009 | Horizon Exercise & Fitness
Horizon Elite 2.1T Treadmill Walking Belt Logo
71 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
