Question about Refrigerators
Refrigirator vent inside has heavy condensation
Freezer is working fine but the refrigerator has condensation at the vent. 72 hrs ago the relay to the compressor was replaced.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 03, 2012
  • 159 Answers
SOURCE: GE refrigerator not cold but Freezer works fine
you need to find out if the evaporator fan in the freezer is working. or if the evaporator is all iced up. If the fan is not working you will need to replace it. If the coils are all iced up you have a defrost problem and that will ned to be resolved. Once a evaporator is all iced over air can not pass through it and you will loose your cooling in the refrigerator first. Check the heater and the terminator to make sure they are good. You can use a hair dryer to clear the ice off the evaporator. Once you find the bad part replace it and the unit will function normally
Posted on Jul 24, 2007
fridgetech
  • 473 Answers
SOURCE: Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Posted on Nov 09, 2007
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
  • 16 Answers
SOURCE: Freezer works fine, refrigeration section will not
Maytags have alot of problems with the defrost control board ... there is most likely snow on the back wall of freezer on bottom.....not caused by thier recall different problem
Defrost Problem
Posted on Jul 22, 2009
The freezer does not freeze the food but the refrigirator is icing up
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 01, 2011 | Hoover HCA330FFK Bottom Freezer...
Model #53092300 Freezer not working this morning. All food and ice thawing out. Thermostats are set at factory settings, air vents are clear. Just cleaned coils 2 weeks ago, they look fine. Refrigerator...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 27, 2010 | Kenmore 53092 / 53094 Side by Side...
The refrigirator is not getting cold
Refrigerator
heatman101
Dec 13, 2010 | LG Refrigerators
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
GE refrigirator constantly changes temprature
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 25, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
It stops getting cold and freezer warms up. then within 24 hrs, its starts working fine again
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 13, 2010 | Refrigerators
Refrigerator fan is running but there is no refrigeration happening. First noticed it a few hrs ago when preparing to fix dinner. All foods in freezer are thawed. email me at dijagro@gmail.com
heatman101
Sep 16, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
The refrigerator is 19 months old. The refrigerator side has quit cooling 24 hours ago and now the freezer has quit working. We have emptied both sides and have noticed ice buildup on the inside of the...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is defrosting and refrigirator is not cooling
If the compressor and the fan work , probably the unit is laeking freon, but if the condenser fan doesn't work ,the compressor will go of on overload, also the problem could be with the compressor relay.
Sep 19, 2009 | Kenmore Refrigerators
Nov 09, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
