Question about HTC One X Android Smartphone Glamour Gray
My HOX won't turn on it's been in a Otto box, so no water damage I don't think. Any suggestions
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Bobbin won't move
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
I have a 12 inch Klipsch synergy series sub. for my surround system and want to put my JL audio 12w6 speaker in the box, will the amp drive the woofer or is the ohms a factor?
ohms is a big factor. also it will probably take more power to drive the W-6 so it won't sound as good. I suggest you don't do it. especially if you can't match up the ohms. You will fry the amp, or it will sound like ****.
May 19, 2012 | Car Audio & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Looking for a dodge caravan engine computer for sale
Don't think I have ever heard of that, ever
You think or were told to find a pcm & your
looking for a reasonable used one ,that hopefully
you won't have to have it flashed?
They don't fail often & I also have never heard of
one being replaced other than at a repair shop
or dealer.
Aug 04, 2011 | 1996 Dodge Caravan
My hhr will not turn off, where is the battery so i can disconnect it
Unplugging the battery won't shut it down I don't think.
Get into your fuse box under the dash or in the engine compartment and pull the fuse for the fuel pump.
Jul 02, 2011 | 2009 Chevrolet HHR
2003 escape turned off while driving had no water it was dripping oil and won't turn on
I have no idea what kind of advice you would like
You could have checked the coolant in the morning
as well as the oil & still while driving you lost a head
gasket & it went into failsafe & shut off
When you say dripping oil, I don't get a good
feeling & your not saying where it is or what
you are doing with your suv.
I wouldn't be supprised if you find out
the motor is ruined,hope not
May 27, 2011 | 2003 Ford Escape
Campbell Hausfeld 13 gal air copressor, when I trun it on it won't build up max pressure and won't shut-off One of the gauges reads 40 PSI the other reads 60 PSI.
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
May 12, 2011 | Campbell Hausfeld 13 - Gallon Air...
HTC One X Android Smartphone Glamour Gray Logo
19 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
