Question about Frost Freezer WCWO F15WA FREE - POCKET HANDLE - L
My Servis fridge/freezer sounds like Darth Vader
For the last week it appears to be constantly on has sounded like heavy breathing & the fridge temperature has just risen from just below 5 degrees up to 10 degrees! The freezer seems to be ok at the moment but I have to go away on business Tuesday for around a week.
Q. will it be ok to leave on or am I likely to come back home to a flooded kitchen
We had the same problem and discovered that the ice making device was "on" and we don't have it hooked up.  In the "on" position the pump begins to run but there is no water to pull so it sounds like breathing.  The ice making bar for us on our Jenn-Air is located near the ice trays and ours needs to be in the up position for off.  Hope this helps!
Posted on Apr 22, 2009
Constant Defrost causing water accumulation problems
Yes! look under you fridge for the consendate drain hose *(usually dangling right over the catch tray) and using a long piece of slightly heavy guage wire snake up the drain hose and see if it's blocked.
If it isn't blocked you might have a crack somewhere in the fridges interior near the fridge/freezer interface. That might be a bit harder to spot since it would most likely be under cover.
Good luck and be careful.
Dec 29, 2009 | Whirlpool Freezers
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Servis fridge freezer mo330al lights
Hi there
  • Green = Ready (Power ON)
  • Amber = Super Speed Freeze
  • Red = Warning overheating or fault.
Hope this helps
Thanks J
Jan 04, 2008 | Freezers
Freezers Logo
651 people viewed this question
Top Frost Freezers Experts
ray gallant
Ken Wieczorek
Ken Wieczorek
Bill Boyd
Are you a Frost Freezer Expert? Answer questions, earn points and help others
