Question about Thinkway Disney Pixar Toy Story 3 Interactive Buddies - Woody and Jessie
Where do i atach the white wire on the battery box of my son pull string woody
Need replacement hat for pull string woody
This is the amazing way for the web users connect to get here this latest version of the adding printer windows 10 i hope you see the function to use this online use the USB cable to plug in the system and have the best image of the print. How to Add Wireless or Network Printer in Windows 10
May 25, 2012 | Thinkway Disney Toy Story Sheriff Woody...
My grandaughter's new jessie doll quit speaking. i don't know if it uses batteries or if the speach comes from a player energized by the pull of the string. is there any way to get the clothes off...
Truthfully, most of the time, you cannot take the clothes off of a Jessie doll. No matter what company, they will always stick to the body, including the boots. Sure, you can take the hat off, but not anything else. If she has stopped speaking, she needs new batteries. THANK YOU!
Aug 01, 2011 | Disney Toy Story Fire Fightin' Woody Pull...
My 4 year old son got the Woody doll for christmas, and he is so attached to him, he goes everywhere with us. My son has never been attached to anything and this morning he woke up and Woody was in bed...
hi, i would call the customer service # and tell them exactly what youve written, make sure and throw in the fact that he is upset and wants to take him to show and tell!
no good solution for today, unfortunately. if you get no where with them, try disney itself, they are the best at customer service and usually can intervene on your behalf.
good luck!
Feb 02, 2011 | Disney Toys
Pulled in the drive way shut the car off went to leave about 3 hours later and nothing at all checked battery,passkey and starter there all good security light does flash and I can't figure it out...
If your security light flashes when you turn the key its your ignition switch. There are 2 little white wires that connect to it and 1 has broke off. What you described just happened to my wifes car 2 weeks ago. Follow the directions that i received below.
The first thing you have to do before you start is take your old key and get a new key made with the right resistor pellet as your old key. They have to cut the new key to the dummy key so it will turn the lock cylinder. The car won't crank with the dummy key cause there is no pellet in it. Some Ace Hardwares sell these keys and are about $26.
Your going to need a steering wheel puller and a lock ring depressor tool. Disable the driver's air bag from the yellow connector under the dash. Remove the airbag and unplug its connector. Disconnect by rotating counter-clock wise the horn connector. Put the airbag facing up on the back seat. Remove the steering wheel nut and use the steering wheel or harmonic balancer puller to remove the steering wheel.
Note: there is a mark on the shaft that lines up on the steering wheel's mark.
Remove the clock spring c clip. Pull the clock spring out enough to let it dangle. Do not rotate the clock spring or it will break later after you reinstall it. Remove the wave washer and depress the lock ring cam with the lock ring depressor tool. Remove the metal ring with picks and small screwdrivers. Remove the tool and lock ring. Unscrew the hazard switch button with phillips screwdriver. Then remove the turn signal
level cam screws from turn signal switch. Remove the three turn signal switch screws.
Go under the dash and unbolt the large connector halves. Just follow the wires that run through and under the column to find the connector. There is a plastic piece that the wires in the column come out of. Squeeze the plastic pieces tabs together and pull the plastic wiring protector out. Undo the small connector that has the two little white wires on it. Pull the turn signal switch out far enough to let it dangle. Using a pair of needle noise gently remove the key chime switch. Pull it out gentle like you are picking a nose hair. You'll see a bolt with an torx head. Remove the bolt and pull the orange white wire retainer from its hole. The ignition switch should slide out.
Tie a piece of string to the end of the white wire connector you unplugged. Then pull the white wires up through the column along with the string. Cut the string from the connector after you fish it out. Tie the end of the string to the new ignition switch white wire connector and gently pull on the other end of the string at the bottom of the dash to fish the wires down into the column. From there everything is reversed.
The hardest part of the whole job is getting that little metal ring off with a pick and/or tiny pocket screwdriver with out poking a hole in your hand.
Sep 19, 2010 | 1993 Buick LeSabre
Replace ignition key tumbler
Sep 08, 2010 | 1992 Buick LeSabre
How do you remove the column ignition switch
The first thing you have to do before you start is take your old key and get a new key made with the right resistor pellet as your old key.(ACE Hardware does these keys) They have to cut the new key to the dummy key so it will turn the lock cylinder. The car won't crank with the dummy key cause there is no pellet in it.
Sep 04, 2010 | 1993 Buick LeSabre
A friend of my son's hooked the jumper cables up wrong on my son's nissan 2002 Xterra. The 100 amp battery fuse blew but welded itself in the fuse box. We tried getting it out and eventually broke the...
This fuse is attached to the fuse box by screws which may be under the fuse box. 100 amp automobile fuses are always fastened in by screws and do not just push in/pull out like lower amp fuses.
Hope this helps.
Oct 12, 2017 | 2002 Nissan Xterra
How do i wire this combo switch correctly. four wires in junction box
1st make sure power is out then
you have 2 obtions
1st thats a regular plug with 2 wires in 2 out
put the 2 white on the white side of the plug
and the black side on the gold
and you should have a ground wire if not most likely its metal box so jyst atach a green wire to it and to the green screw on the oulet turn the power back on if it work good if not
you should call an electrician for obtion 2
Jul 04, 2009 | Leviton 5225WSP Switch and Outlet
Disney Talking Woody Doll - String stuck in pulled position
A friend of ours gave our son a hand-me-down Woody doll with no string at all. I decided to see if I could fix it...about 4 hours, 1 soldering iron, and the realization that my eyes are failing faster than I thought, I was able to return Woody's voice. I'm sorry I didn't take any pictures, but here's what you'll need to do depending on what you find as you operate.
0. Perform of these steps over some sort of container to be sure that you don't lose any of the small pieces that may be liberated in this operation (particularly a small spring that comes later).
1. Take out the battery pack through his lumbar Velcro. There is a black wire that carries power into Woody's thoracic cavity to a module that houses the electronics.
2. You will have to untie, or otherwise get the string through the hole in Woody's back so you can work on it...I don't know what's at the pull end of the string since the Woody we inherited had no visible string.
3. Cut open the white fabric inside Woody that separates battery pack from the electronics module.
4. Take out the two screws that hold the two halves of the module together. CAREFULLY separate these as there are a couple of wires that run between the half with the electronics and the half with the speaker.
5. If you are lucky, which I was not, all the wires will be intact and you will only have to restring Woody. (Nervous sytem work (i.e. wiring) will require a soldering iron and perhaps the assistance of an additional set of hands...)
6. The string is wrapped around a spindle which is spring loaded on one side (it's the big spring - not the little one). With the spindle side of the module towards you (big spring to the lef), the string *should* come up in front of the spindle, over the top and down through the hole..at least think it should. Again the string was broken in ours and once I opened the module, I couldn't tell which way it was originally.
7. On the right side of the spindle is the mechanism that completes the circuit when the spring is pulled. This includes a small spring, and metal piece that makes intermittent contact when the spindle winds back up after pulled.
So, depending on what you see when you take the module and battery pack out you may find:
0. Oh, of course, replace the batteries just to be safe.
1. The string was just hung up in Woody's back and simply removing the module allowed it to be come free again. Piece of cake.
2. The string was bound up around the spindle in which case you just need to clear it and be sure that it winds up properly when pulled. You may need to rewind the string, in which case you need to lift the right side of the spindle (take care to observe how the spring and metal piece are configured...and DON'T LOSE THE SPRING..it took my 10 year old daughter's eagle eyes 5 minutes to find it after it went shooting off the table)
3. The spring mechanism is somehow stuck. This will require tweezers and some patience to sort out the cause.
4. You may have to replace the string. I found some laying around the house that was close to the small shred that remained in our Woody.
5. Finally, I actually had to solder down 3 wires to get the circuit to work. If you're in this predicament, let me know and I will draw a picture for you of what goes where.
In the end, I got Woody to talk again, though he tends to speak without being pulled from time to time. But I gotta tell you, the feeling I got when he burst out with, "Howdy partner, my name's Woody!" was about the best feeling I've had in a long time.
Good luck, and let me know if you need any more information.
Shawn
Nov 12, 2008 | Toys
Thinkway Disney Pixar Toy Story 3 Interactive Buddies - Woody and Jessie Logo
Top Thinkway Toys Experts
ka4iup
ka4iup
woodzowl307
ray gallant
Are you a Thinkway Toy Expert? Answer questions, earn points and help others
