Question about Microsoft 512MB Memory Unit for Xbox 360
I have bought a memory unit and plugged it into xbox 360 exploder..it says memory unit not found. Have tried everything!!!
  • Anonymous Feb 23, 2009
    bought a memory unit and plugged it into xbox 360 exploder says no xbox 360 memory card connected
  • Anonymous Feb 24, 2009
    mine woked fine till i got it my xbox repaired and now my memory card doesnt work in slot a or b
    Problem Solver:
  • 71 Answers
The memory unit could be damaged or dusty inside.
Posted on Jan 29, 2009
I have a 320gb hard drive for my Xbox and when it is inserted it doesn't show on the dashboard for memory devises
In this process your hard drive will be formatted, so back up all files to another hard drive, laptop, or be prepared to lose everything on your hard drive. After you have backed everything up, plug your hard drive into an Xbox 360 then go 'My Xbox/System Settings/Memory.Select 'USB Storage Device/Configure Now' then accept the warning.After the formatting is complete a Performance Warning box will appear, click 'OK.' Now in the 'Storage Devices' screen you should see a new option 'Memory Unit.' This shows that the formatting was successful. Disconnect your hard drive, then connect it to your laptop, load on some media (makes sure the file types are compatible), then reconnect it to your Xbox 360. Your selected media should not appear under 'Portable Device' in the Video/Music/Picture Library.
Dec 27, 2013 | Microsoft Open Box Xbox 360 320gb Hard...
My son has an Xbox 360 slim 4g. I bought him a 320 g Xbox HD. When I install it and turn the system back on I get the red ring and an e68 error. When I remove it it works fine. Please help thanks.I have...
This is called the red ring of death, what I have researched try taking all the memory devices out (hard drive, any usbs, the expansion memory etc...) turn the Xbox on wait for it to boot up once booted turn it back off, make sure all connections for the memory devices are clean reconnect the memory devices to the Xbox and turn it on this should get rid of the RRod error 68.
Sep 08, 2013 | Microsoft Xbox 360 Console
I've bought a Xbox 360 HDD today, I've plugged it into my xBOX and I found is a problem to turn my Xbox ON when the HDD is plugged in. I tried do the same with the another HDD which I've brought of my...
i havn't got an xbox 360 but normely this helps
i think theres ether a problem with your HDD or ur XBOX and you need to talk to the people u got the HDD off and see if they can fix it but if its expensive u probley got a little scammed and u should talk to the makers of XBOX
Apr 22, 2011 | Microsoft Xbox 360 Hard Drive (120GB)
1 red light on xbox 369
hi, here follows a possible solution from Microsoft support:
One light on the ring of light around the power button on your Xbox 360 console flashes red.
You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
c. Press the release button on the hard disk, and then lift the hard disk from the console.
d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
Jul 31, 2010 | Microsoft Xbox 360 Console
Update failed?? cannot find you xbox 360 hard
You must have a memory card or harddrive plugged into the Xbox 360 for the update. Please note that the update might not fit on the memory card
Apr 19, 2010 | Microsoft Xbox 360 Console
Xbox 360 Not Reading 512MB Microsoft Memory Card
try another one, it is probably a defective model.
Jan 07, 2009 | Microsoft Xbox 360 Console
make sure it is fully plugged in and go into settings and then memory and make sure it pops up and then select it if not maybe halo needs a hard drive but i dont think but if it doesnt pop up in memory then its probably a faulty memory stick
please rate well
Jan 06, 2009 | Microsoft Xbox 360 Console
Memory Unit not found
well then that means the memory card you have is no good and or you need to deleate some of the stuff thats on your memory card so put the memory card in the xbox and then over to a purple screen and then go memory and select games click on that and then just deleate the games that are on there and should solve your problum
Nov 02, 2008 | Microsoft Xbox 360 Console
Xbox 360
This behavior occurs when the Xbox 360 console experiences a hardware failure.
Solutions..
Turn off your xbox 360 and remove all memory units and hard drive, power up your xbox again. if the problem appears to be resolved it could be a currupt or bad hard drive or memory unit. follow the above steps again but adding 1 memory unit / hard drive at a time to single out the bad memory device.
Depending on the devices warrenty or where you bought it, you should be able to get it replaced.
If the problem still occurs afetr all memory units are removed try removing all other external devices such as wireless adapter.
if it still occurs it could be something more serious such as the DVD Drive or graphics processor. in which case you will need to call the xbox repair center. they should fix it free of charge for you despite your warrenty under there current "good will gesture" due to the numerous amounts of xbox 360 problems.
hope this helps
Anthony Kinson
Apr 20, 2008 | Microsoft Xbox 360 Console
Xbox 360
Try unplugging everything even harddrive and wait 30 seconds see if that works.
Dec 22, 2007 | Microsoft Xbox 360 Console
Microsoft 512MB Memory Unit for Xbox 360 Logo
315 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
