Question about Sony KDF-E55A20 55 in. LCD Television
Red standby light light blinking
Hi
the red standby light is blinking after i try to turn it on but it wont actually turn on, just blinks red on standby, have googled for an answer with no luck
I have a sony wega 55" lcd. mine flahes 6 times. But if I unplug my tv, then reconnect it a red light flashes one time under lamp. Then 6 times after I hit the power button. Any solution anyone?
  • 3 more comments
  • Anonymous Mar 22, 2009
    i was watching tv and then it turn off and the red light blinks 6 times i try to turn it on but it don't work
  • tomjr679 Apr 01, 2009
    hi i have a Sony KDF-E55A20 55 in
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please intimate exact model number of TV and how old is this TV?
  • Anonymous Mar 17, 2014
    The red LED standby light blinks twice constantly. The TV tries to power up and we see the Sony logo appear and then it shuts off. Replaced the power supply board and inverter board but didn't solve the problem.
  • Anonymous Mar 18, 2014
    a ceiling drip hit top left, no standby light, of course no power to tv wont turn on.
There is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Posted on Feb 09, 2009
  • reyor Mar 31, 2011
    I know its too late but in case anyone else has this problem. There is a simple thermal fuse that goes bad. The fuse is located under the lamp and its slightly tedious to get to but can be done easily in about an hour. Don't listen to tv repair shops they are a scam. The fuse will cost you $5 dollars at the most and a small amount of labor.
  • jacobogundu1
    jacobogundu1 Sep 08, 2012
    Where do I get the fuse from? and how would I go about replacing it?
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sony lcd red blinks 6
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 23, 2014 | Televison & Video
Wont turn on red blinking light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 19, 2013 | NEC PlasmaSync 42MP4 42 in. Television
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Ever time I try turning it on it just says that it is in standby mode and it has a red blinking light but wont play music or anything
hi need model number to help you ..and is the blinking led in any order light or is it just blinking at regular intervals..somrtimes cd players use the led to indicate a service problem or sometimes can be in service mode accidentally..yammandan..
Aug 18, 2010 | JVC Audio Players & Recorders
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The 5 blinks can indicate a picture tube starting to fail. Carefully open up the back and look for the flyback transformer. It will be the part with the large red wire coming out the top that goes to the side of the picture tube. There should be 2 controls on the flyback, screen and focus. Turn the screen control slightly clockwise. If the set stays on, the picture tube is starting to fail and you have bought yourself time to find a replacement. If that fails, then you will need to investigate other possibilities that will involve soldering. Let me know if you need to do that.
The 6 blinks indicate no horiszontal. This can be as simple as a couple of bad capacitors or the "jungle" IC. If you can solder, please post another question with the model and a brief description indicating that you can work in the set and we'll continue to track this down.
Thanks,
Dan
Dec 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDF-E55A20 55 in. LCD Television Logo
1,609 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
