JVC 42" Tv has cut off and when it came back on
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If using a cable box try connection direct without the box---also try to remove power from set and box for a while and then power back.
Posted on Dec 03, 2012
  • 4 Answers
SOURCE: My picture doesn't fit my LG Plasma 42" TV.
Try going to your LG menu , go to screen option and take it off zoom. This could be your problem.
Posted on Jan 12, 2009
SOURCE: My Vizio 42in. is really fuzzy
dressen,
i had the same problem .go up to your upper channels.should be much better.need directtv or hd converter.
Larry
Posted on Feb 02, 2009
ripleymojica
  • 643 Answers
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
  • 15 Answers
SOURCE: tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Posted on Sep 12, 2009
  • 8457 Answers
SOURCE: Cable picture is fuzzy
Ur standard DTV signal picture ok?Not than ur Main Tuner signal board is dead.Must replaced the Tuner signal board.
Posted on Apr 05, 2010
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
Tv picture looks grainy like it was shot on video
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Sound is a little off from the picture
yes, if is still under warranty, you have to tell them the problem and let them fix it first.
Feb 20, 2008 | JVC AV27F577 27" TV
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
Televison & Video Logo
Top Televison & Video Experts
