Question about Marcato Atlas Pasta Queen hand-crank pasta maker, noodle roller and cutter
TABLE CLAMP BROKE - Marcato Atlas Pasta Queen hand-crank pasta maker, noodle roller and cutter
    Champion:
  • 287 Answers
These clamps can be bought 2 ways, look for pasta machine clamp or craft clay roller clamp on eBay. The clay roller entire machine set is much cheaper than the pasta machine, but they have the same clamp.
Posted on Apr 24, 2013
What do you do when the crank to raise the table is broken?
May be. try: thefind.com or ebay.com
No luck? is there enough stem to clamp a small Vice-grip plier on and just leave it there?
Mar 16, 2015 | Drills
How do I make adjustments on my ridged r4512 table saw?
The carriage under the table is held to the underside of the table with several bolts or screws. Loosen those screws.
Raise the blade and clamp a stiff metal straight edge to the side of the blade. Use a carbide blade and clamp the straight edge to the sides of the teeth. Move the carriage around until the straight edge is parallel with the miter gauge slots, then tighten the bolts.
Oct 12, 2014 | Ridgid Saws
Garmon ribbon clamp broke
If the clamp broke, I am sorry to say your unit will not be repairable and you will have to send it back to the factory to be replaced with a refurbished unit. The LCD connectors are installed by a surface mount machine and are practically impossible to align and resolder by hand.
Jul 07, 2013 | Garmin GPS
I broke one of the edges of my ping pong table how do I fix this
This is just an idea. Make a 90 degree angle out of paint stirrers. Connect by using a staple gun. Make sure that there's a bottom on it. Clamp your jig to the table so that it will stay stable. Since it is in the middle joint you can take some styrofoam packing peanuts and squeeze them in there tightly. You can choose what kind of adhesive you use. as long as its very pliable (more like liquid) but will dry hard. you can take a sander to it after it dries to make it smooth.
Dec 30, 2012 | Kitchen Ranges
GROUND CABLE CLAMP BROKE AND IS BADLY CORRIDED
its just taped into the harness you should be able to run a new one along side the harness
Jul 11, 2012 | 1999 Jeep Grand Cherokee
Need replacement table clamp for pasta maker
Have you tried going to the manufacturer's website? I have this pasta maker on my website and you might try one of the links. But you will probably have to get a new machine. You could also go to your hardware store. They might have a clamp that you could use. Good luck.
Feb 21, 2011 | Atlas Translator Atlas 150 Deluxe Pasta...
Bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
Aug 27, 2009 | Bernina Sewing Machines
Drill Presses Installation
Here are a few instructions to follow while installing a Drill Press: Fix the column support to the base using the three screws provided. Slide the table clamp onto the column and align the table with the base and secure it in position using the table clamp lock. Place the head assembly onto the column and slide it down the column as far as possible. Align the head with the table and base and tighten the head locking grub screws with the hex key. Fit the depth scale. Attach the feed wheel. Secure the feed wheel in place with the cap screw using the hex key. Fit the chuck safety shield over the collar of the spindle nose and tighten the clamp screw. Carefully clean out the tapered hole in the chuck and the spindle taper using a clean cloth. Hinge up the shield. Push the chuck onto the spindle and lightly tap the chuck with a piece of wood to ensure proper fitting.
Aug 27, 2008 | Makita TW0350 1/2" Drive Impact Wrench
Marcato Atlas Pasta Queen hand-crank pasta maker, noodle roller and cutter Logo
145 people viewed this question
Top Marcato Atlas Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Marcato Atlas Kitchen Appliances - Other Expert? Answer questions, earn points and help others
