Plastic drive wheel worn out
The cogs on the plastic drive wheel are not meshing withthose on the revolving tray, causing it to hang up repeatedly.
    President:
  • 412 Answers
If you can give a more detailed description of the issue, along with the brand & model name, I may be able to assist you. Jim
Posted on Nov 22, 2013
When it is time for the timer to switch on at night, the red indicator stops right in the middle of on and off.
Plastic gears in this timer. after a while the cogs on the gears get worn until they do not mesh and the timer hangs up.
try shifting the timers time 12 hours. am becomes pm then change your timer pins to the same time but from am to pm or vice versa.
this gets you using another part of the main gear and the timer might work fine. if not you will need to replace the timer.
Jan 29, 2016 | Electric Intermatic Wh 21 Water Heater...
New holland tractor problems
Check for badly worn chain allowing the mesh to get out of sync. Check that the chain is correctly adjusted as if it is too tight then variances in cog diameters overloads the chain and it will break. Check for correct cog alignment and check for bearing condition of the roller
Aug 12, 2014 | Cars & Trucks
Why won't the CD drawer and Cassette door open on my Panasonic SA-PM17 CD Stereo System?
This does happen with CD trays, it's quite common. I can't remember the exact mot common cause, but it's some worn out part, such as a small (plastic) cog wheel. Search on "cd tray won't open" on the internet to find a multitude of reasons, most to do with computer CD trays, but I guess the mechanism is essentially the same. These may also describe ways round the problem.
Some CD players have a small hole on the front near the tray into which poking a straightened out paperclip should enable you to open the tray by a few mm, enough to be able to pull it open in an emergency - but it's awkward to do on a frequent basis.
5.May.2014
May 05, 2014 | JVC XL-F254BK 5-Disc CD Changer
Rear wheel or final drive assembly
if its a constant wining sound a bearing or cog is worn and needs sorting b4 it fails
Dec 28, 2013 | 2002 Yamaha V Star 1100 Custom
My shuang ma 9101 will not fly forward
I had the same problem. The problem is to do with the little cog in the back of the helicopter that drives the tail rotor. If you reverse the helicopter it creates downward movement but if you fly forward it creates lift. This lift can actually cause the white plastic gear wheel to also lift and it looses contact with the drive cog itself. Undo the two screws to lift off the black casing, prize off the white plastic cog and file the underside down slightly. When you put it back in place it now sits slightly lower and does not lift too high when you fly the helicopter forward. Hope this helps.
Jan 27, 2012 | Toys
CD/DVD tray will not open.....happy to purchase a new CD/DVD component WITHOUT speakers if cant be fixed but cant find one....
These get stuck on everything with or without a disk. My advice is to take the cover off and see what it is hanging up on. It is almost never a motor. I would bet something is just off a bit that is causing the stick. There should be 4 to 6 screws to remove the cover and that will expose the drive itself. There will be a gear in there too that is usually white and plastic. That could be off the cog and just needs a tap to get it back on track.
Jun 16, 2011 | Sony BRAVIA® DAV-HDX279W Theater System...
The cd tray to my hifi is not woring
If there is a disk in the tray that is not properly located this may be causing a jam - you may be able to get it open by carefully pushing something thin (like a credit card - or another disk ) in to the top of the tray slot to hold the disk down - take care not to push it all the way in!). At the same time prise the bottom of the tray VERY gently with a small screwdriver whilst pressing the eject/open button.
If that is not the cause of the problem the plastic cogs or the rubber drive belt that operate the tray mechanism may be worn / broken. Repair/ or replacement of these components is possible if you can locate the correct parts (try Ebay) but as CD or DVD players are so cheap to buy it may be simpler just to replace the whole unit.
Feb 26, 2011 | Audio Players & Recorders
I have a craftsman 625 self propelled mower and the drive system that makes the wheels pull the mower are not engaging. How do i fix this?
More than likely the problem is with the drive wheels at the front. The cogs are most likely worn away - happened to me about 2 or 3 years ago and have the same problem again. Poorly made - cogs are plastic. You'd expect the cogs to be made of metal. Cannot order them from the States as Sears don't ship across the Atlantic. Have to try and get them in the UK.
woofagee
Sep 16, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
My 2000 saturn LS slips out of gear when driving and now I can't get it into any gear except third. Is the tranny punched...
does the shifter feel normal??? the cables are a common problem. if it feels like it goes into gear but slips out, the trans may be bad, but verify the cables first.
Oct 16, 2009 | 2000 Saturn L-Series
The center roller bearing worn out, the plastic cog-wheel is out of center
are you sure it is the bearing ? normal deal is the cog wears like that from the chain running on it a bit loose over time the cog and clutch drive are a normally due to be changed every 2nd chain or every time the bar is changed also if it was the bearing if it is a 2 stroke motor the engine would not run because it would **** air into the crankcase
Aug 09, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
k24674
jasbo
jasbo
