Question about Sebo Felix Classic Bagged Upright Vacuum
My hoover brush will not turn
My brush will not turn, no blocked areas, nasty noise when turning off but suction in hose
    Top Expert:
  • 14,553 Answers
It has a belt that may be broken or jammed that turns the brush.
Posted on Dec 03, 2012
Testimonial: "have watched video and seems quite straight forward thank you "
  • 1 more comment
  • lindseymi817 Dec 03, 2012
    didnt know it had a belt as brush removed easily?? can this be easily replaced?
  • SD Tech
    SD Tech Dec 03, 2012
    usually can, if no belt either it is direct drive or the belt came out
  • lindseymi817 Dec 04, 2012
    ok thanks
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Loss of suction o=with hose tool
Hose or tool is probably clogged. Is this an upright? Bagged or bagless? Have you changed the bag and filters? Cleaned out the brush and hose that goes from the brush area to the collection bag/cup? The only reason for a vacuum cleaner to lose suction but still work is a clog or dirty filter which blocks the air flow. Follow the air flow from the brushes to the bag/dirt cup. If the machine is bagged, change the bag. I use another vacuum cleaner to do this.While your at it, might as well change the belt.
Nov 15, 2011 | Hoover Vacuums
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Not picking up
Did you check down by the brush roll? If the hose has suction, then the problem has to be in the nozzle asm. The hose having suction tells you that the main part of the vacuum is working ok.
Mar 17, 2008 | Eureka 7618 Bagged Upright Vacuum
No Suction in Hoover U6450-900
If there is no suction, check the filters, if they are clean then there has to be a clog either in the hose or in the inlet down by the brush roll. See if there is suction at the hose end. If there is, then it is clogged down lower. Are you sure that the brush roll is turning when it is on the carpet? For a manual, go to www.hoover.com, put on your model number, if one is available, you can down load it.
Jan 07, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Sebo Felix Classic Bagged Upright Vacuum Logo
171 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
