Question about Refrigerators
Frigidaire gallery FRS26ZSH ice maker won't dispense from the chute
Frigidaire Gallery fridge FRS26ZSH ice maker won't dispense from the chute. Make ice fine just chute door will not open when you choose the ice/crushed ice buttons. Chute will open if I push on it when door is open.
  • 51 Answers
SOURCE: Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: door ice dispensor will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Posted on Mar 17, 2009
  • 91 Answers
SOURCE: Ice not dispensing. Chute opens but motor does
First try removing all the ice, then try operating. You could have a block of ice that is so solid it is not alowing to turn.
Posted on Aug 26, 2009
SOURCE: Ice maker only producing crushed ice, only I have
We had this problem and have visited several friends houses in our neighborhood who all have appliances of approximately the same age, 6 to 7 years old and found this to be quite common.
The solution to this specific problem was rather simple, and has proven effective on several different brands, to the relief of many befuddled husbands and frustrated wives and now happier children.
Though the mechanism is in a slightly different location on some models.
I removed the ice hopper and looked in the back of the freezer and found the steel drive prongs that power the feed screw inside the ice hopper.
An inch down and a few inches to the right of it I found the mechanism that actuated the arm to open the chute for cubes or keep it closed for crushed ice. (on the Frigidaire Gallery Series)
I held the interior light switch closed and had someone push the ice lever on the outside and observed the drive prongs turn, but the mechanism that actuated the arm to open the chute did not move.
Stuck my finger in there and pushed it upwards manually and after a brief moment of resistance it moved freely.
Re-tested the operation of the mechanism that actuated the arm to open the chute, and it now opened when the ice lever was depressed and set to cube, and stayed closed when it was set to crush.
With the money we saved on the service call, I took the family out for chinese food.
Posted on May 14, 2010
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice aker ks, but does not dispense ice. fgidaire gallery, sde by side
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
Sep 26, 2014 | Frigidaire Gallery GLHS38EGSB Side by Side...
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery FRS26ZSH. Frezer is iceing up. The circulating fan is working. I pulled it apart and defrosted it and it has reiced
Frosting of ice may increase with aging of the fridge. All that you can do for that is defrost it at times. There's a special process for fridge mechanics by which they say they can fix the problem, but believe me, it's of no good. I've done it a couple of times. If you are in a financially sound situation, try replacing the fridge.
Apr 21, 2010 | Frigidaire FRS26ZSG
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
