Question about Kokido Zap Vac Automatic Pool Cleaner
Where can we purchase parts for Kokiko products?
Looking for a replacement part on our vaccum that makes the vaccum swivel. We do not have a part number as there was no manual included with purchase.
Plastic flap where hose attaces to vaccum has broken
What make and model is it so i can look and see if you can buy the part or not also does the part that the hose go into swivel or is it fixed solid
Mar 18, 2008 | Vacuums
Tip
How to Find Shark Parts and Accessories
There seems to be many people that are looking for parts and accessories for their Shark products. Shark does have a website where they sell parts and accessories for their products.
Whether you are looking for parts for you Steam product, Upright vacuum, Garment care product, or your hand or cordless vacuum, you can find any of the available parts here.
Go to http://www.sharkclean.com
Then at the top right under the search box, hover over the parts and accessories tab.
A drop down menu will appear and you can choose which product you want to see the parts for.
Click on that product and you will then see separate boxes for parts and accessories for all of the products in that category.
Click on the product you have and then you will see a list of parts or a list of accessories available for that product.
There are many parts available for their products, but I would not say that they have available every part that could possibly break.
There no parts that pertain to the heating function, so if your product stops making steam for instance, there are no parts that can help you fix that.
Broken handles are fixable and are there. Replacement heads and replacement head coverings are there as would be expected.
If you are in need of parts to fix a product that is not heating, I would suggest looking for used products on Ebay or something like that. Also advertising for a used product may also get you the parts you need...unless of course they are selling it because of the same problem that you had...make sure to check that out first.
heatman101
Also checkout these other related tips...
http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
http://www.fixya.com/support/r6740629-shark_steam_pocket_mop_cleaning_problems
on Nov 18, 2010 | Vacuums
How to replace swivel lock arm on DC25
There is no such part please advise correct names
Oct 07, 2014 | Dyson DC25 All Floors Bagless Upright...
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
Is it possible to download a user manuel for a vacuum? I purchased mine out of the box.
hi!!! looking the picture of your vaccum, it must be the U5140900.
here you are the manual for that vaccum:
http://www.hoover.com/pdfs/manuals/U5140900.pdf
if yours is a different model, please send me the number.if this help you dont forget to rate my solution!!
have a nice weekend.
jess
Sep 17, 2010 | Blair Hoover Widepath Tempo Bagged Vacuum...
Looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Jul 23, 2009 | Kirby G6 Bagged Upright Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Kokido Zap Vac Automatic Pool Cleaner Logo
Top Kokido Vacuums Experts
JoeVacs
Are you a Kokido Vacuum Expert? Answer questions, earn points and help others
