Question about Polaroid PDV-0823A Portable DVD Player
Need fuse for 12V adaptor
DOes anyone know what size to use
    Champion:
  • 303 Answers
Agc 3amp
You can buy a new ac adapter by clicking on the hyperlink:
buy replacement ac adapter power charger cord for POLAROID pdv-0823a pdv0823a
Posted on Mar 05, 2009
Hi my engle works fine on 240 v but not on 12v .....thnx
Got a few thing you can try
1. Check the fuse in the 12v cigarette lighter adaptor, it unscrews at the base, it needs a 10A glass fuse
2. ALWAYS switch the thermostat to off before going from 240v to 12v
3. Some of these have 2 different sockets on the back, check you are using the correct one
Failing this its probably a problem with the inverter inside the unit
Hope this helps
Apr 10, 2011 | Engel Commercial Refrigerator
Can I use an universal power adaptor with my western digital my book hard drive, as a replacement for the shipped power adaptor?!
Yes, if you get one that has the appropriate specs. The universal adapter needs to be able to output the exact voltage (e.g., 12V), it needs to meet or exceed the amperage spec (common units are mA and A, 500 mA equals .5 A), and it needs the proper shape/size plug with matching polarity (for example, +/- on in/outside).
Jan 28, 2011 | Western Digital 500GB My Book Pro-External...
My External HDD's adapter blow and i want to know if any 12v adapter will make it work?
Be careful, not all 12 Volt adaptors are the same. Some put out AC voltage and others DC. You need a 12 V DC adaptor. The adaptors are polralized, that is one output wire is + 12 V and the other is - 12V.. If you connect it backwards you can blow your hard drive.
If your not sure regarding correct polarity, consult a technician who knows how to use a voltmeter.
Also, the current rating of the replacement adaptor must be equal to or greater than the currenr rating of the original. Example: Old adaptor = 375 Ma. , New adaptor = 750 Ma. This would be OK.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 02, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Hello. I just bought an older, used Meade LX200 18...
The scope will run just fine on 12 volts. www.scopestuff.com sells the cigarette lighter cord for that telescope.
Call them here:
www.scopestuff.com
May 16, 2010 | Optics
I have a Duralast Jump Starter BP-ELG and the power cord got thown away I need to know the voltage, the current and the polartity.
Since you say, it is a 12v DC portable Jump starter, the battery inside it is also a 12V battery. You need a 12V charger (eliminator, wall adaptor or whatever you may call it) Regarding current, it could be anything above 500 mA. Better if it is a 1A or 2A or even 3 A depending on the amount you are willing to spend. Now is the most important part. The polarity. I do not know it since i do not have this equipment. Most chances are that you will find (on the RoadPro) a circle and a dot (along with a +VE and -VE marked near it) around where you plug in the adaptor. For most equipments the outer circle is the -ve and the inner dot is the +ve. (unfortunately this could be reversed in some equipments) If you can find this notation on your RoadPro you are lucky. Just go to any electronic shop and buy an adaptor (12V) that matches this circle and dot notation. The same symbol representing polarity will be marked on the adaptor also. Else, you will need the assistance of someone who can check the continuity using a multimeter. This way you can find the polarity. It is pretty easy. Hope this helps.
Jan 11, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
2008/09 Camry 12V Outlet Fuse Rating?
It will go to 30.In one sense you dictate up to 30 as it depends what the items rated amps are.The things you plug in are what you need to check
Oct 18, 2008 | 2008 Toyota Camry
Minolta DYNAX 500si
Martindawn,
the T-adaptor for celestron is 1/14 inches. go to-------
wwwtelescope.com for anything in scopes & acc.
May 08, 2008 | Minolta Maxxum 500si 35mm SLR Camera
Polaroid PDV-0823A Portable DVD Player Logo
128 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
