Question about Samsung SC-D382 Mini DV Camcorder
It has an arrow the it says R beside it - Samsung SC-D382 Mini DV Camcorder
I want to unfriend a person on facebook
go to ur friends account and u can see a down arrow mark beside friends option . then by selecting that arrow u will an unfriend option......
Aug 20, 2013 | Computers & Internet
How to log out in facebook
  • ON THE TOP MOST OF THE FACEBOOK PAGE LOOK FOR HOME
  • BESIDE THE HOME THERE IS AN "ARROW POINTING DOWNWARD" CLICK THE v BESIDE THE HOME THAT IS BESIDE YOUR NAME
AND IT WILL SCROLL DOWN AND YOU WILL SEE "LOG OUT" AND CLICK "LOG OUT"
Dec 04, 2012 | Computers & Internet
How to thread the machine. pfaff creative 7570
I just went across to FAcebook and found Pfaff there and from there a link to manuals online, yahoo. Thankyou Pfaff.
Here is link for the manuals page
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf
Its a bit tricky, click on the blue arrow beside your model, then click again on the blue arrow beside "English", then click on the blue underlined text "owners manual" to see the PDF file download.
Oct 17, 2011 | PfaFF Creative 7570
I was told i need to take a test so i can ride out and go shopping or something like that how do i do that
u go to the Dressage riding hall and talk to Mrs. Mullan, then click the right arrow ONCE and then it will say something like, "Riding Test to Town" then click on that and read the directions.. the 4 arrows are behind the academy, behind the dressage riding hall, beside the stables, and beside the Western riding hall..
Feb 16, 2011 | Viva Media I Love Horses: Riding Academy...
My cd/dvd drive isn't showing up in "my Computers" and further more when I insert a cd or Dvd nothing happens. i tried downloading a dvd driver from dell but the problem still continues. What shall i do?
what is that? laptop or desktop, because laptop isn't easy to open and but in desktop you can change dvd drive.well, if you drive is not showing anything, that means either is disable or is not connected properly? have you seen that your drive's property?just right click away to check and any lighting indicated process, the LED light will start blinking if the computer is communicating with your drive. good luck,
Jun 21, 2010 | Sony DVD-ROM DVD Drive
My toshiba laptop doesnot play dvds . sattelite pro A 120 .
try this step wadhwa823.
Click start
click run
type the word regedit
then click the arrow beside HKEY_LOCAL_MACHINE
then click the arrow beside SYSTEM
then click the arrow beside CurrentControlSet
then click the arrow beside Control
then click the arrow beside Class
then click the folder beside 4D36E965
remove the upper and lower filters on the registry
Restart the machine and check if you can play DVD's
May 24, 2010 | Toshiba Computers & Internet
Dvdrw on my advent 7113 will not read any discs
try to click start > type RUN and hit Enter > and type Regedit and click OK
on the registry editor click the arrow HKEY_LOCAL_MACHINE , then click the arrow SYSTEM, then click the arrow beside CurrentControlSet, then click the arrow Control, then click the arrow Class, then click the folder 4D36E965
, then remove UpperFilters and LowerFilters.
Restart the computer and check if the DVDRW will read...
May 09, 2010 | Computers & Internet
How do reset radio after replacing battery?
Answer There is a Up and Down Arrows beside the audio button, Press the arrows for about 3 seconds and it will beep, It will change the Hour and Min.
Oct 14, 2009 | 2001 Chevrolet Impala
Hi. messenger just keeps freezing. and cannot find my uninstall files to reload
Do the following to delete your old Yahoo Messenger from your system completely:
1. If you are running Windows Xp, Go to the Start menu and click on RUN.
2. Type REGEDIT (short form for Registry Editor)
3. Click on the arrow beside HKEY_LOCAL_MACHINE, click on the arrow beside Software and search for the file to delete.
4. Restart your system and install your Yahoo Messenger again.
Regards
Sep 09, 2009 | Yahoo Messenger
Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is...
this is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Jan 22, 2009 | Computers & Internet
Samsung SC-D382 Mini DV Camcorder Logo
16 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
