Question about Ricoh Aficio 3025 All-In-One Laser Printer
Error sc 650 en la ricoh 3025 aficio - Ricoh Aficio 3025 All-In-One Laser Printer
SOURCE: ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Posted on Jun 05, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
  • 7 Answers
SOURCE: how i reset error sc 546 on ricoh aficio 4100n
Turn the machine off, hold down online & escape, turn machine on and wait for "1.Service Menu"
Select service menu, find sp 5-810, select #/enter, when it says "execute select #/enter, then escape. Turn machine off then on.
Posted on Oct 24, 2009
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
Mon copieur ricoh aficio 201 affiche sc 120 error
netoie la bande blanche sous la petite vitre du chargeur
Mar 30, 2013 | Ricoh Aficio MP 201SPF Printer
Error code sc 650
Ricoh AF 3025 error code SC650 is wat problem?
Jan 03, 2012 | Ricoh Aficio 3025 All-In-One Laser Printer
Como quitar el error sc 819 de una ricoh 3025
• Software application error
• RAM shortage
• HDD error (hard disk drive )
Apr 06, 2011 | Ricoh Aficio 3025SP Copier
ME SALE SC 550 EN LA RICOH 1085 PORQUE ES ESO, QUISIERA QUE ME ALGUAN RESPUESTA
Standby temperature error 1
Symptom:
Fusing temperature failed to
drop to expected level within a
given time (15 seconds, 15
minutes, or 25 minutes,
depending on mode) after
entering standby or low-power
mode.
Possible Cause:
• TRIAC short
• Fan not running
Nov 25, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Mi ricoh aficio 1013 sale error SC 552, quisiera saber a que se debe eso....!
así usted tiene un problema con la unidad de fusión, antes de llamar a un técnico que usted podría tratar de restablecer el código al entrar en el modo de servicio y restablecer el código de allí. Siga los siguientes pasos y usted podrá fácil de hacerlo:
1. pulse el botón (amarillo [C] cancelar)
2. a continuación, pulse el número en este
orden 1-0-7
3. a continuación, pulse el botón (rojo [C] parada) y por algún tiempo, hasta que en la pantalla LCD no aparece el menú de servicio.
4. cuando vas a ver el menú de servicio en la pantalla, oprima el número 1 sobre la almohadilla de número de la tecla y presione (OK) y luego con el cursor de flecha derecha al lado del botón (OK) Pulse hasta que vea en la pantalla el número [5.Mode ], cuando este está en la pantalla pulse el botón [OK] y luego otra vez con la flecha del cursor al lado de la [OK] pulse hasta que en la pantalla aparecerá el número de [810. Perdí mi código SC] cuando este aparece, pulse el número 1 en el número de teclado (confirmar que en la pantalla que está escrito el número 1 y presione juntos la tecla [OK] y la tecla para seleccionar el tipo original (esta clave se encuentraen el marco del [Aceptar]) Ahora que usted ha reinicia la máquina por la que se escuchará el sonido como empieza cuando se enciende por el tiempo que los abetos también si usted no presiona la tecla junto obtendrá un [error] en la pantalla LCD si esto suceda, inténtelo de nuevo, si después de algunos momentos de tratar de que no son capaces de reiniciar la máquina llame a un técnico.
Jan 14, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
I have a ricoh Aficio 3025 all in one, it is now giving me a fault code of SC543 please advise
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Nov 12, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio 3025 All-In-One Laser Printer Logo
308 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
