Question about Uniden Bearcat 855 Xlt 50 Channel Scanning Radio 800 Mh Excellent With Manual
Need antenna my antenna broke i need an antenna for a uniden bearcat 855 xlt 50 channel scanner
  • Uniden Expert
  • 509 Answers
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Posted on Dec 07, 2012
johnny5846
  • 379 Answers
SOURCE: i am having trouble clearing
hi marie , follow these instructions carfully ,
1. Place the scanner on it's back on a hard surface with it turned "OFF".
2. Press down and hold down the following keys with your left hand. (MANUAL), (2) and (9)
3. While holding down these buttons, use your other hand to turn the scanner power "ON". Continue to hold all the buttons down until you hear a "click" and all the channels are cleared to 000.0000.
hope thats a fix ya .
Posted on Jan 03, 2009
Mechanic688
  • 204 Answers
SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Posted on Feb 12, 2008
Communicomm
  • 90 Answers
SOURCE: Uniden Bearcat Scanner Model# BC147XLT
The BC147XLT is too old to obtain a manual from Uniden, but here's how you program it:
Turn it on & press 'Manual', then enter the number of the channel you wish to program & press 'Manual' again. Now enter the frequency you want to put in that channel, example 155.550, and press "Enter'. Then press manual to go to the next channel or repeat the first procedure to select a different channel other than the next one. Repeat the programming procedure for each channel.
Posted on Sep 26, 2008
  • 160 Answers
SOURCE: need to know how to put codes in
it's allready programed for u
Posted on May 09, 2009
BillB-SA
  • 2761 Answers
SOURCE: manual for Bearcat Scanner BC 140 10 channel
I couldn't locate a manual for your oldie, but it's fairly simple to operate.
  1. Turn the scanner ON.
  2. Press "Manual" to stop scanning. Use the keyboard to choose the channel you want to enter your first frequency into. If you want channel 2, press the number 2 on the keyboard and then "Manual" again. If you want channel 12, press the 1 and then the 2 and then "Manual" again.
  3. Enter the desired frequency, including the decimal point. For instance, if the frequency is 555.789, enter 5, 5, 5 and then the dot button, then 7, 8 and 9. Then press "Enter" to complete the setup.
  4. Use the "Manual" button to move to the next channel to enter the next frequency. Continue this process until you have all frequencies entered.
  5. Complete your entries and then press "Scan." Set the squelch by turning the "Squelch" knob all the way up and backing off until you hear no static.
  6. Lock out a channel that is annoying you by pressing the "Lockout" button. If you want to listen to the channel again, simply select "Manual," find the channel by entering it on the keypad and then hit "Lockout" again
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Posted on Dec 12, 2009
My scanners hasn't been turned on for sometime and wnat to program it but scanner is stuck on one channelBearcat Uniden 800Megs.police scanner model BC 855 XLT..
It used to be that you could reset a Uniden scanner by holding down the #2 and #9 buttons while turning on the radio - that MIGHT do a factory reset for you. Let me know.
May 07, 2014 | Uniden Radio Communications
Uniden bc147xlt manual
the Bearcat uniden 144-xlt and the Uniden Bearcat 145=xlt are the same scanner, the only thing it the case on them are different so they could sell new scanners eachyear. Those manuals will work for the bearcat 147-xlt, hope this helps some people out there
Jan 04, 2014 | Radio Communications
How do i start scanning for channels on my bc 855 xlt scanner
Firstly, you need to program your favourite frequencies into it, before you can receive anything, all the info on setting up your scanner is in the user manual that came with your scanner, if you bought it new, that is.
Cheers,
Peter
Jul 26, 2011 | Uniden Bearcat Pro PC78LTW 40-Channels...
Antenna concteor broke on a bc560 xlt police scanner and how to fix it
probably have to carry it to a scanner shop or send it in to bearcat company.....
Jun 04, 2011 | Uniden Radio Communications
I have a Uniden Bearcat "BC 855 XLT" scanner. It scans properly, the antenna is good and the solder connection is good. Yet is will not recieve a signal even the weather. What part needs to be replaced?
There's no telling without completely troubleshooting the unit, and that would likely cost you more than the unit is worth. Used BC855XLT scanners are selling for between $15 and $30 on eBay . . . .
Bill B
Listening in since the 60's
Oct 11, 2010 | Radio Communications
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Uniden Bearcat 855 Xlt 50 Channel Scanning Radio 800 Mh Excellent With Manual Logo
234 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
