Question about Envion TPP101M %2D 90 TP 101TW02 Therapure Air Purifier
Thera pure TPP101M stopped working
Wont turn on at all
Thera Pure. Why won't it turn on?
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
Jul 23, 2015 | Air Purifiers
Pure pro fan motor
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 12, 2012 | Montgomery Ward Pure Pro Air Purifier
Manual
no just a switch on cover that has to be pushed in by the cover before it will be safe to turn on
Apr 04, 2010 | Brookstone Pure-Ion UV Air Purifier
My machine is 4-5 years old and it suddenly wont turn on. I switched outlets but it appears dead.
Open up the elecrical panel and see if you have any fuses form the incoming power if you do it might be blown
Aug 31, 2009 | Sun Pure SP-20 Air Purifier
How to troubleshoot a Pure Ion #AP-75 non-working
My ionair cleaner doesn't clean the air what so ever. All four filters are perfectly clean after running for over two months. All of them are properly inserted and seated as specified. No filter warnings turn on and the unit works in all other ways. There is an ongoing fire in the hills nearby and our house if full of hazy smoke.
Aug 08, 2009 | Brookstone Pure-Ion UV Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Pure-Ion not working?
Didja wash the plates? It takes a little maintenance, and there are a lot of things that could make it stop working (Magnum, anti-aircraft fire, someone tripped over the cord, power quality in Karachi is lousy, there's pudding in the works...) but washing the plates with dishsoap and water, (then drying them before trying to start again) ought to fix most things that could be wrong.
Sometimes a fiber (a gift from a guest, maybe) is protruding into the works that needs to be removed, but those are the main reasons.
Jun 20, 2008 | Brookstone Pure-Ion UV Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Device is inoperable
I've had the same problem since the first time I tried to turn it on. I have to press the on button 20-25 times over a period of 5 min. to get it to work.
Feb 01, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
Envion TPP101M %2D 90 TP 101TW02 Therapure Air Purifier Logo
393 people viewed this question
Top Envion Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Envion Air Purifier Expert? Answer questions, earn points and help others
