Need compac speaker stands
I lost the speaker stands that slide into the slot at the bottom of the speakers when you don't want to mount them to the computer. Can anyone help me find some to purchase. Thanks L.T.
  • Lindley Krone Dec 06, 2012
    JBL could not help.
  • 7,627 Answers
Go to the speaker manufacturer website for a replacement. Ebay.
Posted on Dec 05, 2012
IB4G2008
  • 3587 Answers
SOURCE: no sound thru Altec Lansing speakers on computer
maybe the plugs going into the back of computer are unhappy..can you do a continuity check on the prime and ground of those?
Posted on Mar 15, 2008
  • 50 Answers
SOURCE: I cannot get my speaker to work on my dell
1. speakers should be connected to the lime green port at the back of your desktop
2. Go to Control Panel > Sound and Audio Device > Audio Tab and check sound playback device make sure you audio device is selected
3. Reinstall your audio driver, you can download it here:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=122481
Posted on Jun 11, 2009
McSuber
  • 20 Answers
SOURCE: I have no sound on my computer-emachine T3095
The type of speakers you choose for yourself have several factors that come into play:
your location (does your sound have a volume limit such as a noise ordinance in an apartment complex)
What are they being used for (music, games, movies, work, voip chat)
Your music genre preference (heavier bass means you will want an actual bass)
sound quality (are you an audiophile or does sound quality not truly matter to you.)
I got a decent pair of 5.1 surround sound speakers for just under 100$ by logitech, but a buddy of mine purchased a 300 dollar set that shakes his room when he plays FPSs
Posted on Jun 25, 2009
  • 59 Answers
SOURCE: my computer lost sound. Audio driver ok. Speaker
check for the Audio Output port for any damage. Make sure the speakers are connected to the Green Output port. Reinstall the Audio drivers if neccessary.Try good known speakers if you have one.
Posted on Nov 14, 2009
birky09
  • 104 Answers
SOURCE: JBLPro Compac computer speakers wont work
Well from what you said no device, it was not detected because of your new magic jack. There might be a conflict in your hardware. Try scan plug and play devices if it can detect your jbl or reinstall both you devices.
Posted on Dec 01, 2009
How to take the grill off a peavey sp-5
Most versions are obvious, but the newer version where there are no screws on the grill edge require you to remove the bottom plate on the cabinet by taking off the feet and stand adaptor. Once the bottom is off, you'll see the grill is mounted in a slot. With the cabinet on it's back lift and pull the grill and it will slide up and out of the slot.
Jan 25, 2013 | Peavey SP 5 2-Way 15 Speaker
Need driver for Logitech Z-340 speaker system.
Sounds like the Subwoofer is blown. Unless you are handy with this stuff, you're outta luck unless you can find someone with the expertise to replace the blown speaker inside. This is not an easy job. If you are up for it you can follow the previously described method for opening it & removing the blown speaker. A suitable replacement can be found at http://www.rpelectronics.com/d03-0004-4-speaker-paper-cone-4-ohm.html Note that it will need to be mounted differently than the original which is mounted on the rear of the panel.
The replacement must be mounted on the front. It will need some sort of gasket (foam tape or something) between it & the panel. No soldering is required as push on connectors are used. Connect it up after installation and reassemble the unit.
Be aware that there is a possibility that the sub's amp is blown, in which case replacing the speaker is of no use. It would be good if you had some sort of speaker to connect to the terminals once you get the unit open and check that the amp is putting out before ordering a replacement speaker. Good luck!
Nov 17, 2012 | Logitech Z-340 Computer Speakers
Need to know what size speakers go on a 1965 ford ranchero
Made me laugh and reminisce. One time my dad bought a 1957 ford 2 door hardtop. I was about 14 years old, so just starting to drive. Driving that car was a real gas, but at any little bump, the rear end bottomed out and made a loud whump!
Find a wiring diagram from a repair manual for the number of speakers. Don't know what size, but wherever the speakers are located, the mounting hole and dimensions should help you figure it out. Also try googling ranchero. You might find an enthusiasts forum that you would like to join.
Nov 18, 2011 | Cars & Trucks
I replaced the 2 ohm 6x9's in my buick with the monsoon amp, with 4 ohm 6x9's. After i put the speakers in, almost no sound came out. I've read that you can wire them in parallel from one...
If you did wire these in parallel to get the 2 ohm load, you will loose your balance. Also, you may have to bridge your amp.
To do this, go from the positive of the amp to both positives of both speakers. Then from the negative of the amp to both negatives of both speakers. If you have a 2 channel amp, you will have to bridge it. Note, make sure your amp is 2 ohm stable.
hope this helps
Aug 27, 2011 | Car Audio & Video
Just bought a Harbinger HX121M 2" Monitor, from Musicians Friend it did not come with a booklet on how to wire into my sound system it has two 1/4" jacks and a strange round plug about the size...
If you don't know how to connect this... well we don't either because you did not tell us what your sound system is. The larger plug is what is known as a "Speakon" connector and is a fairly reliable speaker connection that is used now. For your use you will PROBABLY use either of the 1/4 inch jacks with a cable from the amp that will drive the monitor(s). If you have multiple monitors you will daisy chain them using the 1/4 inch jacks and SPEAKER rated cables creating a string of speakers with input going into one and an output from the same one to the next speaker and so on...USUALLY you will be limited to two speakers per amp output...
Aug 15, 2011 | Harbinger HX121M 12" Stage Monitor
Goes straight to protect mode, detached speakers, still same problem
HI, if the unit is in protect mode then there may be the possibility that the speaker wires may have a short circuit in them or that the amplifier section may be damaged....you can remove the radio from it's sleeve and check the wiring behind the unit...this also would have to be done to see the model number and serial number...it should be on either the top or bottom of the unit...the speaker wires for this unit are the white, gray, green, and violet...each with another of the same color but has a black stripe in it...the black stripe is the negative side of the speaker wire....you can disconnect these wires, then turn on the unit to see if it comes out of protect mode...if it does, then there is either a bad wire somewhere in the car or a bad speaker...if the unit stays in the protect mode, then you will have to take the unit in for repair, as this indicates a circuit failure
One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, usually with the green power LED on the amp turning to red or orange. Here's a brief troubleshooting method that will hopefully help you if your amplifiers ever go into protection.
1. Try to determine the cause. Amplifiers can go into protection mode for several reasons. Knowing what happened before it quit working can help determine how to fix it. Did the amp malfunction as soon as it was turned on? Did it happen after blasting for hours (may be thermal overload and it needs to cool)? Did it cut out after you hit a bump (a wire connection may have come loose)?
2. Tear it down. Get the amp down to it's most basic state. Remove all of the speaker wiring and RCA wiring and leave only the power, ground and remote leads connected. If you still have a problem in this state then either your amp is defective or you may have an installation problem such as the amplifier touching metal.
Remember that an amplifier should only be connected to the vehicle through the power and ground terminals. Mounting the amplifier to the metal of the vehicle, including putting the mounting screws into metal, can cause problems for your amplifier. Always mount the amplifier to a non-conductive surface. An easy way to accomplish this is to mount the amplifier to a wood board and then mount the board to the vehicle. Don't let the amp touch the screws used to moun the wood board and don't use screws so long to mount the amp that they go through the board and touch the vehicle.
3. If the amp is OK in this torn down state start reconnecting wires until you find what causes the problem. Add the RCA cables first. Then add the speaker wires one at a time. If the speaker wires cause the problem then they are probably touching metal. Check to make sure that a speaker wire isn't being pinched somewhere between the amp and the speaker. Also check that the speaker wire or speaker terminals aren't touching the vehicle metal near the speaker opening. Rear decks and door panels can easily touch unprotected speaker terminals if not properly installed.
If you believe your amplifier is defective contact the manufacturer first. Many have flat repair rates that are very affordable and cover parts and labor as well as return shipping. However local repair shops may be cheaper if it is just a small repair. Compare the manufacturer's repair rate to that of a local shop. If you don't know the reputation of the local shop it may be better to send it to the manufacturer who will have working knowledge of the amp and parts readily available.
Hope it helps..
Aug 10, 2011 | Sony STR-DE698 Receiver
LMy JVC CD player reads PROTECT across the screen even after resetting the cd player it still reads PROTECT, I'm so lost now because I don't have amps or anything attached just regular car...
Try checking your speakers and speaker wires for shorts and/or grounds. Make sure none of your speaker wires have any bare spots. If your speakers and speaker wires are fine, you may have a bad internal output ic inside of the deck.
Jul 14, 2011 | JVC AM FM CD DET FACE CAR STEREO
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
No speaker hook up on new moniter
If your old monitor was a Compaq, it had slots for the speakers to hang on and provided the power for the speakers. The speakers still got their input from a cable that plugged into the computer sound output jack. If those speakers are the style Compaq supplied when I worked at a Compaq service shop, they originally came with metal stands that fit into slots on the back so you could stand them up on their own, and a 12-volt power adapter so you could use them without the monitor. If you don't have those pieces, you can buy a suitable power adapter (12 volts DC at 1 amp) at Radio Shack but the speaker stands are hard to find. You could try eBay, or just make a holder of some kind. (A friend of mine used those little wooden stands you can buy to display plates to hold her speakers when she got a new monitor. They worked out pretty well.)
Or you can replace the speakers. A new set would have everything you need. But those Compaq speakers sounded pretty good, so if they're still working you might want to keep them.
Dec 22, 2008 | HP Compaq Computer Speakers
Need screw size for Bose 901 Lifestyle speaker to mount to PS6's
Had the same question, e-mailed Bose support and they suggested "# 10 woodscrew, 4.5 mm diameter".
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
Computers & Internet Logo
David Payne
David Payne
