Question about Brother PE-150V Computerized Sewing Machine
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
  • Brother Master
  • 7,365 Answers
Try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Posted on Dec 03, 2012
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
  • 7 Answers
SOURCE: My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Posted on Jan 03, 2009
picatudo
  • 239 Answers
SOURCE: Upper thread won't pull up lower thread
adjust needle lower it down
Posted on Mar 10, 2009
i had the same problem and realized i was using the wrong kind of bobbin. there are specific ones for an embroidery machine and specific ones for a reg. sewing machine. hope this helps
Posted on May 03, 2009
  • 1116 Answers
SOURCE: The needle does not pick up the bobbin thread.
Check the needle - is it bent. Is it in backwards (flat side to the back is correct), or is it threaded from the back to the front instead of from the front to the back.
Check the bobbin to be sure the thread is feeding in the proper direction and the thread is not caught in the cover for the bobbin area.
If none of this helps, then the machine needs to go into the shop for service.
Posted on Apr 23, 2010
I am having problems with the bobbin its not picking up the bobbin thread through the needle
thread the upper part and the needle put presser foot down hold loose end of thread with felt hand and turn the wheel with right . the needle goes down shuttle wraps the bobbin thread around the upper and when needle comes up the bobbin thread will be with it . OR have yo MOMMA SHOW U HOW
Feb 18, 2015 | Sewing Machines
How do I reassemble drop-in bobbin case for Brothers XL 2600 free arm?
Do you have some pictures of the area involved. I know how to put these things back but I can't think how to explain it to you.. pics might help me show you.
Brother has an outstanding service department, and if you don't have a manual, they should have one. Should have a pic of how it goes together.
Aug 02, 2014 | Brother XL-2600
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
I recently received a Juki TL-98Q and a long arm quilting machine. Everything is set up and I have put two sheets with cotton batting between them on the machine so that I can practice. I cannot get...
Hi Donna:
This has two parts; 1) pick up thread, and 2) needle hole direction.
1) To begin and pick up the bobbin thread, typically I start without any material under the arm. Begin with a tail of thread about 6" long pulled out from the bobbin, leave it loose. Then holding taunt, onto about 3" of the upper thread after it leaves the needle, I cycle the machine once. Then it should have captured the bobbin thread. Raise the pressure foot (with the needle 'UP') and slide something between that gap to pull out both threads (Upper and Lower), a ruler or your thread trimming scissors are handy for this. Pull the threads and you should see both upper and lower threads now, ready to sew. Apology for covering this basic item, but . . .
2) As you move into 'new' machines, sometimes the needle is no longer setup with the hole front to back. The gotcha is that on some (bigger) machine the hole goes side to side (yes the needle is rotated a 1/4 turn). As a rule of thumb, the thread goes through the needle and points right at the hook. Small machines may have the bobbin right 'behind' the needle. Larger machines often have the bobbin (and hook) beside (often to the right) of the needle. That means to install the needle with the hole going left and right, and the cutout groove pointed to the side with the hand-wheel.
End.
Oct 11, 2017 | Juki TL-98Q
Upper thread breaking while quilting
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 12, 2011 | Sewing Machines
My bobbin thread will not thread. When I bring the needle down, it comes up without the bobbin thread. The mechanism moves, but no thread. How do I fix this problem?
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
Sep 01, 2010 | White Sewing 2200 Multi-Tasker
Cant bring up bottom thred even after we read how to
re thread the upper and lower threads
make sure the bobbin is in the correct way (check manual for the correct spin on the bobbin clockwise or counter clockwise
change needle or check that it is in correct, if it has a flat side goes to the back, the long groove on the needle when goes down should just meet with the hook in the bobbin area to pick up the thread
Sep 07, 2009 | Elna Sewing Machines
Bernina 801 Sport
Did you clean out the lint under the plate?
Feb 27, 2008 | Bernina Virtuosa 160
Problem with threads not catching
Try putting in new needles. Make sure they are in the proper position. There is a stopper which keeps the needle down far enough to make the right connection. Sometimes the needle stopper, after long use, moves up a little which prevents the needle from going low enough to pick up the bobbin thread. You could try lowering the needle just a little. Not to far, or it will break the needle. Sewing machines need a lot of oil. Not all at once but a drop or two after an hour of use. All lint needs to be removed from under and around the bobbin before it is oiled. Keeping the machine clean and oiled is the life of the machine.
Zelma
Dec 26, 2007 | Bernina Bernette Deco 600
Brother PE-150V Computerized Sewing Machine Logo
369 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
