Screen flicker toshiba
Screen flickers may or may not go dark (blank). After shutting down and restarting I could get into the bios (F2 key ) and changed the default value for monitor screen type from auto to LCD. Screen stayed on but still had flicker. Kept feeling that it would go dark again. Changed the refresh rate from the default value of 59 hertz to 60 hertz (the only other value available on the drop down list). Screen still had flicker - no change. The laptop is about 3 years old. Used daily, never dropped, always used an auxiliary cooling fan. Any suggestions as to cause or fix? Thanks Mike
    New Friend:
    Problem Solver:
  • 9 Answers
Sounds like you need to think about buying another laptop. Or replacing the LCD screen. Search ebay or amazon for screens.
Posted on Dec 03, 2012
PyroMan6x9x9
  • 150 Answers
SOURCE: laptop screen
Sounds like the switch that tells the cpu when it's open or closed is going bad. On most laptops there is a little switch that protrudes from your keyboard (usually in upper corners). Try cleaning it with isopropyl alchol(rubbing alchol) and a q-tip and see what happens. If you can't locate the switch on your model get back to me and i'll research a little deeper for you. Hope this helps
Posted on Sep 14, 2007
rahul26485
  • 611 Answers
SOURCE: Flickering Screen
1. Access the System Settings menu
2. From there, select the CONTROL PANELS folder.
3. Double click on the DISPLAY icon in your Control Panel.
4. Click on the SETTINGS tab.
5. Click on the ADVANCED button.
6. Click on the ADAPTER tab Select the preferred refresh rate in the drop down box.
Posted on Jul 07, 2008
  • 788 Answers
SOURCE: Same Problem, No apparent reason, Screen flickers, goes out
You may want to rule out a loose connection.
Move the laptop screen back and forth and see if you notice any flickering.
This does not sound like a software issue, so we can rule that out.
If you have a consistant brightness on the display, we can rule out the backlight.
Their are two connection points on the display monitor, one is just under the power button and the other is behind the LCD screen.
I was going to suggust plugging into a external monitor but can't really see any outcome in that.
It may be a inverter problem, that is located inside the LCD, just behind the HP square design. You will find a input and output.
If any of these connections have come loose, that would cause the flickering.
If the backlight is consistant in value, you can rule out the lnverter.
If the unit has been dropped, it can be any of the above.
With the 20 min. to 6 hours useage, I would go with the inverter. If after the unit cools down for a few minutes, it works again, its the inverter.
Hpoe this mess of info has helped.
Posted on Aug 27, 2009
Damienc
  • 103 Answers
SOURCE: monitor flickering
hi tim, get the latest drivers here : http://support.acer-euro.com/drivers/downloads_gd.html
o/s is abbreviated for operating system = windows
kind regards
Posted on Jan 17, 2010
Testimonial: "good indeed!"
SOURCE: Thinkpad T30 - LCD Not working
I dropped my laptop and screen was verry hard to see unless u shined a bright light at it. the inverter just under the lcd screen happened to come unpluged. I dont know if i was just lucky or if this has happened to more people. I hope this helps some one else.
Posted on Dec 30, 2011
Toshiba laptop upside down to to fix it
If your problem is the screen of the laptop being upside down, please try to press CTRL+ALT+Up Arrow Key or Down Arrow Key, after you see some flashing or flickering on the screen restart the computer.
Sometimes you need to login first on the computer then press the key combination i mentioned then it should fix the problem.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Toshiba Computers & Internet
There is this green line flickering at the bottom of the screen of my system,i have changed my screen before and the thing started again, i dont know what to do. Any advice will be welcomed, thanks
Welcome to fixya.
First you have to reboot the pc to bios to see if you have the same flickering green lines. So you have to restart your laptop and keep on tapping f2 to get to the BOS. If you have the same flickering on bios then you have to replace your LCD screen. If not. then you can go windows and uninstall and reinstall the video driver.. If you get the same results. lower your resolution. and your refresh rate.
Hope this help you out...
Jul 15, 2011 | Computers & Internet
My Toshiba laptop L505 screen starts flickering and continues to get worse until it resembles a strobe light. If I turn it off it will be fine for a little while and thene do the same thing again. Is...
If it would be a video card driver problem, you could still fix it, but if would be the video card itself, then you need to replace it.
Here what you can try.
- If you have an external monitor, connect it to your laptop. Observe if you will get the same flickering screen.
- If yes, download and install an updated video card driver from Toshiba website. Make sure that it is compatible for your Operating System (Linux, XP, Vista or Windows 7) and system model.
***NOTE: If updating the video card driver will not resolve the issue, surely the video card is failing. It needs to be replaced.
- If no, the problem is with the LCD of the laptop. Consult a professional technician to help you check LCD cable, LCD inverter and LCD itself.
- If you don't have any external monitor, go to the BIOS setup (either pressing F2..(it depends on what key was designed for it)..at the manufacturer's logo). If the screen will flicker at the BIOS setup screen, consult a professional technician to help you check LCD components.
Hope this helps.
Jul 11, 2011 | Toshiba Satellite L505-S5966 Notebook
Hp pavilion dv5, flickering screen problem mostly when 26" external monitor is connected, Using Windows Vista 32bit
First restart the computer and tap f10 key on keyboard to enter bios, and check wethere the screen flickers or not you can even try to tilt the screen and check as the drivers doesnt works in bios screen ... if the screen flickers then it is a hardware issue .. if it doesnt then log on to safe mode with networking by pressing f8 as the notebook restarts and then go to device manager by typeing device at the start search and the uninstall the video driver and then reinstall it from hp.com support and drivers ..issue will be resolved if not then do a bios update from hp.com, support and drivers.
Apr 29, 2010 | HP Pavilion DV5-1000US Laptop
I have a toshiba laptop & half the keys on the keyboard won't work
Try to go first to Safe Mode.
Bring up the "Start" menu. Select the "Shut Down" option and then click "Restart."
Wait for the Toshiba Satellite A105 laptop to begin its restart procedure. Press the "F8" key at regular intervals (every 3-4 seconds) when the Toshiba logo pops up on the screen.
Continue tapping the "F8" button until the advanced Windows options menu appears. Use the down arrow key to scroll through the list of advanced Windows options.
Highlight the option labeled "Safe Mode." Press the "Enter" key and wait for the operating system to load in safe mode.
On Safe Mode try to use the keys that are not working if it's woking it's a software problem and you need to have a System Restore for the laptop.
If it's still not working go to BIOS Settings of the laptop try to reset it to default settings.
Hit the "Power" button to turn on the computer. Press the F2 key on the keyboard. This must be done prior to the operating system loading; if the Windows OS logo has popped up, it is too late. Boot into Windows, restart the computer, and try again.
Pressing F2 on a Toshiba laptop takes you directly into the BIOS, and any settings can now be changed.
If you have successfully entered the BIOS Phoenix press F9 there will be an option that will pop out after pressing F9 the choose yes, after that press F10 there will be an option that says "Save and Quit." This will save any changes you've made, exit out of the BIOS, and restart the computer. Choose yes again, after that process the laptop will boot up now to your Windows Screen.
Try to use again the keys that are not working, if it's still not working definitely that's a hardware problem, you need to contact Toshiba Technical Support here's the phone number
800-247-7777
to assist you further with this problem or you can drop your laptop to a nearest Authorize Service Provider for Toshiba near in your place.
Hope this helps. :-)
Mar 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Screen display is not stable.screen flickers
CHECK IN BIOS. If the screen is flickering in BIOS then it is hardare issue.
1.Please power ON the notebook, Keep tapping F10 as soon as you power it ON.
2.Press the F9 key to reset the BIOS defaults, it will ask to restore defaults. Hit Yes.
3.Press F10 and save the changes.
In BIOS please check if you can see the flickering. If the screen is same in BIOS then it is hardware issue. If you do not see the screen flickering in the BIOS then please update the BIOS and graphics driver
Feb 09, 2010 | HP Computers & Internet
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
Satellite A25-S279 screen flickers and goes blank after 5-10 secs
are you getting image on your LCD while booting up in the bios and windows loading screen ?
if yes, then perform a windows installation.
Aug 24, 2009 | Computers & Internet
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
Computer screen is upside down
u need to open the monitor control menu by pressing the menu key on the monitor then select the option showing two bent arrows one facing up and the other down, then adjust.
Mar 14, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
