Question about Sharp HT-SL77
Sharp wireless subwoofer flashing red
I recently set up this system in my home and the speakers work fine, but the subwoofer never seems to work. It just flashes red and never connects wirelessly. i have tried moving it to different locations and re-linking it to the reciever but have little to no luck(it worked once briefly but never worked again)
  • 97 Answers
SOURCE: sharp sd nx10_out signal trouble
Try all of the spaekers on the channel you know works. If all are fine, swap the speaker lines to test them. Is the input a DVD player on RCA cables? A bad signal cable from a component can be a source for problem. Connect the speakers directly to the amp(if possible) bypassing the sub box. If all works without the box, suspect bad crossover or in the self-powered boxes a bad amp.
Posted on Jun 25, 2007
  • 208 Answers
SOURCE: connect head set to sharp lc-26d43u tv
The audio out from those jacks requir amplification and will not drive a head set. Get an inexpensive stereo receiver and run the audio out of your TV to the receiver and use the receiver for your headset.
Posted on Jun 29, 2008
mickspaceNET
  • 115 Answers
SOURCE: sharp 1642CS shared printer
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
Posted on Nov 05, 2008
  • 362 Answers
SOURCE: no sound from audio output This set is new.
The speakers need some kind of amplification, if you have something like a set of computer speakers connected and they are not powered they won't work, try connecting them to the headphone jack.
Let me know the set up, what kind of speakers, audio settings from the tv menu.
lone99star
Posted on Jan 09, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Posted on Jul 23, 2009
Poping noise comes from speakers every so often but recently has then crackled and lost connection to my ps4 and virgin box
When it warms up the failing electronic components in the sharp unit fail, they reset when they cool down again. The speakers are almost certainly fine, but the main sharp unit has an electronic failure that is cheaper to replace it than fix.
Dec 15, 2013 | Sharp HTDV50H Theater System
No sound from subwoofer
Make sure your front speakers are set to small in the setup menu. Regardless of how large your speakers are, if they are set to large the receiver will put the low frequency sound out the speaker jacks and turn off the subwoofer output
Nov 26, 2012 | Pioneer VSX-818V-K Receiver
My two wireless speakers are not working. the wireless receiver flashes blue 10 times then turns red. It was working fine and now is not
I am having the same problem with my LGHB905TAW. Called local support without any feedback... I think this is the bug in design phase.. Search around the internet but without any positive result...
Sep 27, 2011 | LG LHB975 Theater System
Philips DC912/37 will not pair with the subwoofer. I have had the device for 2 years, and the subwoofer stopped working recently, and now it will not pair with the tuner.
This worked for me. Try it and it should work for you all as well..;-)
Frequently asked questions See all FAQs Question How do I get the main unit to recognize the subwoofer? Answer Wireless connection will set up automatically when you switch on both the main unit and subwoofer.
Sometimes you may encounter the problem that the main unit does not recognize the subwoofer. Try the following process to solve the problem:
  • They are heavily interfered by other wireless home appliance such wireless network, TV etc. Move the subwoofer to another place, the main unit will auto detect & recognize it.
  • Switch off the main unit and the subwoofer and then switch on them again. The main unit should recognize the subwoofer automatically.
If neither of the above works, try to pair with them manually.
  1. In standby mode, press and hold the 090518075138_27245.gif button on the main unit (PAIR flashes on the display screen.) to activate signal transmitting.
  2. Press and hold the PAIR button on the rear of the subwoofer (You will find the LED indicator on the subwoofer flashes in blue and green alternatively) to activate signal receiving.
The wireless connection will set up automatically and the main unit should recognize the subwoofer now.
Dec 21, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
How can i pair my subwoofer to the main unit
Oct 13, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
Wireless digital transmitter doesn't work
I'm having this same problem; it worked all ok in the beginning then one day it didn't and no matter what I try it doesn't seem to connect. Similarly im getting the W1 flashing and even when I take the receiver and move it closer (even within a few feet) it still wont pick it up. I've removed the wireless home phone and baby monitor from within the room without any result. I cannot think of anything else that could be interfering. Any advice or resolution would be much appreciated.
Oct 06, 2009 | Panasonic Audio Players & Recorders
$150 wireless speaker
use a expanded module for input/output RCA ports, Radio Shack
Jun 15, 2008 | Brookstone Outdoor Wireless Speaker...
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
Sharp HT-SL77 Logo
64 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
