My philips acdc tv has no power when in dc mode
  • ralph casto Dec 05, 2012
    I have checked the fuse in the power cord. Is there an internal fuse
  • SD Tech
    SD Tech Dec 05, 2012
    Yes would be my answer---all AC/DC units I have ever seen have a DC fuse inside them as well.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
AC/DC sets have a fuse for each of the power sources--on DC side it can be in the cable or inside the set---that is the first thing to explore.
Ones with a lighter adapter on the DC cord will have the fuse inside that.
Posted on Dec 03, 2012
Philips/Magnavox 27TS54 C101/chassis 27B800-7562. Originally would not turn on at all. Replaced C506 (totally scorched) as other posters recommended. Now turns on but only bright white horizontal...
check for power supply for normal dc voltage..try resoldering the vertical output ic or test the vertical output ic dc supply..if there is..try finding some loose connection to the deflection circuits
Jul 13, 2011 | Philips TS2768C 27" TV
I have the ultraslim combo ac/dc charger. On the plane, using a standard plug through the power brick, there was no power to the laptop. I tried several different seats with the same result, while other...
The plane may have been running 400 Hz. power through the outlet, and your charger's input filter was blocking it so you didn't have enough voltage getting through. The other passengers probably did not have as much inductance (high-frequency filtering) in their stuff.
Mar 19, 2011 | Lenovo 90W Ultraslim ACDC Combo Adapter...
I have a Philips Magnavox 17MD255/17 LCD TV. I can not find the actual ac/dc power adapter, they are no longer available. Which one would I be able to use?
http://cgi.ebay.com/NEW-AC-Adapter-Philips-Magnavox-17MD255-17-LCD-TV-/270636758732
try this they are all 12v 5a so you can do it on your own
Sep 22, 2010 | Philips 17MD255V Combo
Hi, have a philips 42pf7321d/37 tv that won't turn on, I replaced 2 capacitors that were bad but when I tried to turn it on again two leds on the power supply turn on making a clicking noise they stay on...
Hi.
The clicking noise and the leds on mean that there is an incorrect voltage value detected from the main controller board. When this happen we say that the main controller is forcing the PSU to standby, sending the set in protect mode.In protect mode only
The PSU can be tested bridging the low voltage control lines that are turning the higher DC volts from PSU on.
The procedure to test the PSU is illustrated in the following article. I wrote the article for LCD, but the procedure is more or less the same on your plasma. Simply disregard the part on inverter (plasma work in a different way and have no inverter or backlight system) How to test an LCD TV or monitor PSU
Bridging the voltage lines is a repair suitable for an experienced technician. If you are a DIYer, better testing the resistors and components near to the faulty capacitors by reading Ohms to check if they have continuity. This operation is done with power not connected.
If you need to replace the whole board, here the part number: POWER SUPPLY UNIT LJ44-BLAH101C PHILIPS. The part is temporarily out of stock, and may be available ordering from Philips.
Here the service manual:
PHILIPS Chassis EP1.1U AA Service Manual.
May 06, 2010 | Televison & Video
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Artists list
You must go in and manually edit the Id3 tag for these songs in Windows Media Player- time-consuming, but necessary
May 26, 2008 | SanDisk Sansa e200 MP3 Player
Philips Magnavox 17MD255/17 LCD TV had AC voltage applied.
It seems your "power regulator" a small unit inside tv device has damaged due to wrong power supply. In this case usually the power capacitor burns and few other electronic components like triodes. Get the help of a electronic chip technician to replace the damaged components.
Hope it works.
Mar 28, 2008 | Televison & Video
No dc power for philips 27pt543
there is a known issue in deflection circuit specific to capacitor 2455. normal recommendation is to replace that capacitor and 2 transistors right next to that location 7461 and 7463. symptom was specific to random startup and shutdown issues and components should be replaced before proceeding.
Feb 14, 2008 | Philips 27PT543S 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
