Question about Hayward Pool & Spa
Lo error on hayward pool heater
When pool heater is turned on blower starts, heater ignites then LO error is displayed and heater goes into shutdown phase.
  • Hayward Master
  • 1,631 Answers
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Posted on May 25, 2015
SOURCE: "LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Posted on Jun 07, 2009
  • 5 Answers
SOURCE: Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
  • 61 Answers
SOURCE: Hayward H250 giving me a "LO" error code and does not turn on.
9 times out of ten this means that you have a faulty water pressure switch. It could also be a limit switch, or air pressure switch. Make sure the filter is cleaned, and all valves are in the correct position. Once you are CERTAIN that water is flowing through the heater, you will need to short each individual component to find the faulty one.
Posted on Apr 11, 2009
  • 139 Answers
SOURCE: hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
Posted on Jun 21, 2009
  • 4 Answers
SOURCE: my hayward heater gives a LO error when trying to
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
Posted on Mar 01, 2010
My Hayward H series gas heater will not stay ignited when I turn it to Pool the Display reads LO if I shut pool filter On and off fast it will almost start but then goes back to LO display is there a...
  • Etc
May 02, 2014 | Hayward H Series
LO error
error codes don't appear on millivolt units. LO for digital models is an open safety within circuit, most common being the pressure switch
Apr 08, 2014 | Hayward H Series Pool & Spa Heater 400k...
HAYWARD h250 LO error
  • Etc
Nov 09, 2013 | Hayward H Series Pool & Spa Heater 400k...
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
Our hayward heater H250 model was installed last year.. this year it started up after the winter no problem. We put it on Standby mode while the poolliner was being replaced and not it will not come on.....
Thank you for posting your question here on Fixya.com.
A 'LO' error code for a Hayward heater is a limit string open error. If the limit string opens the heater shuts down and goes into lockout. Automatic restart is 2 minutes after the error condition is corrected and the limit string closes.
The limit string is a series of switches designed to turn off the heater if air or water temperatures exceed a safe operating limit.
The problem may be faulty a switch(es) but is far more likely to be a system condition the switches are reacting too that needs to be corrected. Low flow of combustion air due to obstructions around the heater or the vent; low flow of water through the heater allowing too high a water temp; Poor venting or sooted-over heat exchanger causing flame rollout; inlet and outlet hose connections reversed; these are all conditions that should be eliminated if they exist.
If you are not familiar with these switches or the conditions described you may want to consider calling in a professional. Hayward can refer you to someone in your area who is. Call Hayward at 908-351-5400 or try the website locator found here. It is likely to still be covered under warranty.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jun 08, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
Getting LO error
Lo is an error code dealing with the safety loop, hi limit switches, water pressure switches. Check for continuity and the wiring between the hi limit switches and the water pressure switch. Also, check to make sure the filter is clean and the pump basket is empty. These also can cause a low flow situation that will cause the pressure switch to not close properly.
May 23, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
HAyward H series gas heater 2500i
There is a thermistor temperature sensor beside the inlet union on the heater that goes bad, it looks line a stainless steel nut with wires on it. You can unthread to replace it and it plugs into the board behind the display. The LO means low pressure probably caused by pressure switch adjustment.
Jul 07, 2009 | Hayward Pool Products Hayward 200k Ng H...
Hayward pool heater c4205 has error message of LO
Jun 20, 2009 | Hayward H Series Pool & Spa Heater 400k...
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H400 heater problem
LO usually indicates low water pressure. Check the pressure in your filter. You may need to backwash. If the filter is to clogged then the water pressure in the heater is so low that it won't activate the pressure switch. While checking the pressure turn the pump off and then on to make sure the pressure gauge is actually working. Also check the pressure coming out of the inlets into the pool. You should be able to tell if you have sufficient water pressure.
Jan 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
81 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
