Question about Belkin (F5D7230-4) Router (587009)
I cant change my belkin wirelees channel
I need help changing my wireless channel from 6 to 11
  • JDTec
    JDTec May 11, 2010
    Did you hit apply after changing the channel?
  • Belkin Master
  • 4,338 Answers
Belkin Router:
Go to 192.168.2.1
when the setup page comes up,
Click on Channel and SSID on the left column.
It may ask you for a password, if you have not previously set a password, just click submit.
On the next page change the channel and make sure you click apply. then click on logout on the top right corner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 11, 2009
Wireless connection keep dropping every 10 15 mint, but the direct (wire) stay connect ?
check channel , try to change channel to 6,11 . check the long way between your device and router . if not soluted , try another pc to check disconnection , if disconnected the problem with your wireless router , if not the problem with your wireless device
Sep 05, 2013 | TP-LINK TL-WR740N Router
I was on my ds and i went to Nintendo wi fi settings and it asked me to input my wep key and now i cant figure it out.
BELKIN ::::
Hi ,
By Default the security in the Belkin is WPA and unfortunately the DS Doesnt support this
To enable WEP in the Belkin follow the Steps Below
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Feb 13, 2011 | Belkin Basic Wireless Router
Samsung r540 laptop cant make contact with belkin basic model F7D1401v1
Dec 21, 2010 | Belkin Basic Wireless Router
Keep losing signal to wireless, have to disconnect power to router then power back up and its fixed
I think you may need to change the wireless channel number or you need to update the firmware of your belkin wireless router. In order to change the wireless channel number you need to access belkin default page. you can refer this Change Belkin Wireless Channel number and SSID
Aug 09, 2010 | Belkin (F5D8231-4) Wireless Router...
Wireless inop says its connected showing full green bars on pc , but wirelees speed is 1.0 mbps
In case there are many WiFi signals in your area, try changing Belkin's channel at another one, because it's limiting down the speed in order to keep the connection alive.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 10, 2010 | Belkin F5D9231-4 Router
Hi I cant get my PSP to connect to my Belkin
The WEP CODE Is the Password for your wireless network
Dec 21, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have buzzing on my phone when my Belkin n modem router is on . i have just brought new Uniden 5.8GHz phones i have 2 adsl line filters but stil the buzzing persists can you help
The frequencies of the phones and the modem are causing harmonics. You should have the ability to change channels on the phones, just turn the phone on and when you hear the buzzing start changing channels on the phone till it stops. You should have at least twenty five channels on the phones. Hope this helps.
May 17, 2009 | Belkin N1 Vision Wireless Router
Cant get internet connection on my laptop
You need to change the wireless channel on your wireless router. Using your wired computer, open the router's setup page by going to internet explorer and type http://192.168.2.1 and press enter. It will prompt you for username and password. By default the username is admin and leave the password blank. Look for wireless tab and look for wireless channel. Change it to channel 11. Make sure to take note of the Wireless Security key as well under wireless security tab. Save the settings after changing the wireless channel. On you laptop, make sure to disable any firewall then try to reconnect to the wireles network.
Apr 25, 2009 | Belkin (F5D7231-4) Wireless Router
DSN conversion
- Kindly try to change first the LAN IP Address of your router to 192.168.2.1.
Mar 14, 2009 | Belkin (F5D7231-4) Wireless Router
Router loses connection to Internet
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. SummaryWireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.
Nov 08, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
52 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
