Question about Kitchen Ranges
Thermostat not working in main oven - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
Oven not working front lights for main switch and thermostat and internal light not coming on oven wont heat only fan is coming on oven 1 year and a few months old
Check if a overtemp fuse has beem avtivated. You will need a multimeter. Check for burned wires on function switch and thermostat. And check functionswitch for burn marks. Function switch = main switch
Feb 13, 2016 | Ovens
Electric fan oven
Sounds like the oven thermostat stuck, for whatever reason and then the oven overheat thermostat kicked in. At the very least, I think you will need a new oven thermostat and possibly an overheat one as well. On the 720 there are two, one for each oven, so when you take the oven to bits, check both out.
Dec 17, 2011 | Stoves Ovens
Hotpoint oven thermostat replaced again a few months ago now oven working but thermostat bulb not. Can this be replaced and how ? Thanks
Depending on which thermostat you are talking about , the main oven thermostat is complete with with sensing bulb, so is replaced as a complete unit.
The other stats, including over heating stat, and cooling fan stat do not have a sensing bulb, they are a bi-metal device, and can be replaced individually.
Nov 14, 2010 | Ovens
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Baumatic B151 Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
