Washing machine not working
Will not run programe, even on spin only
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
namzyanzy
  • 435 Answers
SOURCE: beko aa washing machine does
If your dryer doesn't spin or dry at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Thanks
Posted on Sep 15, 2008
  • 103 Answers
SOURCE: CMD 126 candy washing machine struggles to spin even at low load
hi your balt is sliping or your ford geers are ded
Posted on Apr 05, 2009
  • 7 Answers
SOURCE: Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
Posted on May 05, 2009
beltronic205
  • 1466 Answers
SOURCE: my beko washing machine just spins ? even if the
Sounds like faulty motor speed control module. 1st make sure taco plug not fallen off @ motor..
Posted on Nov 17, 2009
SOURCE: Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Posted on Feb 17, 2010
Why does drain pump keep running even though machine is emplt
it will keep running during and after the spin cycle until the program shuts the machine down
Jul 23, 2017 | Washing Machines
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Aquarius wt745 hotpoint machine need to reset the pogram - as machine program not working properly
You have said "Every Program" but I'd like to make sure that's the case. The issue you're describing is highly unlikely to be programming. More likely I would suggest, is that the heater in the machine has failed. As a result, a 60 minute program (Which is planned to take 60 minutes taking into account the average time the water takes to heat up), will run for AGES while the machine waits for the heter to get the water up to temperature, which it can't because the heater is dead. Firstly, test this theory by running a 60 degree wash and feeling the door glass after 20 minutes. It should be HOT, my guess is it will be cold. Also, If I'm right, a cold wash program will run fine (Rinse and spin for instance) As will spin and pump out settings. If this isn't the case, then there is a possibility of a blockage. Though you have said the pump works, I would suggest disconnecting the waste pipe from your drain and putting it into a bucket. Fill the machine and then pump out. The water should FLOOD out VERY fast. If it's slow or a trickle, there is a blockage in the pipe or pump.
Sep 06, 2015 | Hotpoint Washing Machines
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
Washing machine won't spin, will do everything else including drain
have you got any buttons on the m/c that say with hold spin or similar will it spin on any other program as some times with the same program running all the time the clock wares out so it wont go onto the spin program
Sep 28, 2012 | Washing Machines
Washing Machine starts and then halts when runs
there is a PCB fitted inside the machine which gives comand to the electical moter and the water pump and it is programmed to give those comands on regular time intrvals as per the programe selected by you if the machine is not working according to the programme that means PCB is malfunctioning due to many reasons like moisture in the cercuit or dry solder etc try to remove moisture by blowing hot air through it if still the problem persists change the pcb your machine will run normal
Aug 14, 2012 | Fisher and Paykel Washing Machines
Whirlpool WW1206
WW1206 Whirlpool Washing Machine CONTINUOUS WATER PROBLEM.
Water is continuous once the system says it to open, thus the program stops there and no more spinning. Water level setting is not functioning. Water inflow stops only when pressing the pause position. Even if the water supply is cut off, no spinning is experienced. The program still continues and waits for the automatic water supply cut off as programmed, but the water level indicator does not work. rince and spin programs work because there is no supply of water in the program.
PLEASE KINDLY ADVISE
Jan 17, 2011 | Whirlpool Washing Machines
My washing machine overflowed and would not drain. When it is on water keeps coming in even though the machine is full iof water but there is no movement of the agitator and I could not get it to...
H i there.....sounds like you've got either a failed water inlet valve....or a disconnected /ruptured capillary hose from the pressure switch to the tub....or a failed pressure switch........turn water to appliance off.....turn program selector to drain or drain /spin..is drain pump running...if not it may be blocked or burned out....or with machine empty of water.....turn program to spin....if no spin...check motor....
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
