My rca is stuck on channel d9-1 and all buttons only control my volume please any answers
All of my buttons on remote and tv only control my volume and cant change channels on niether tv or remote please help
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Try to unplug set and whatever is being used for signal from power, if set returns to normal operation you may have to delete that channel from the set memory.
Cable or Sat boxes can cause this issue by confusing the micro processor in the set.
Posted on Dec 03, 2012
SOURCE: RCA Colortrak 2000 remote control
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Posted on Dec 15, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
ginko
  • 19396 Answers
SOURCE: TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
Posted on May 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: I lost the remote and cant find a universal that
you can go to menu options, than find programming options.
Look for an option called "autoprogram" and select it. It will search and set all available channels.
There is universal remotes for this tv that you can find by googling "elements electronics remotes":
Posted on Jun 06, 2009
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Tv is not working it is stuck on channel 3 and stays there and need it to go on output in front and can't watch any channels with direct tv satalite very difficult lost remote and need code this tv and...
Hello
If you have its original remote control you can unlock its parential settings and reset it. Then only you can watch other channels also. I'm ver sorry to say that if you lost your TVs remote control, you will be unable to unlock it. Try to get a remote from any of your friends who owns the same model number RCA TV. If you are able to get it, do the following with that remote, and reset the V-chip. Try to purchase one new remote control from RCA.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK
Happy New Year
Dec 31, 2010 | RCA TruFlat 27F520T 27" TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
Cant change to any channel
Unknown password--chassis ITC008 with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
need RCA remote with clear button
Jan 01, 2010 | RCA 27R410T 27" TV
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
TV is ON....only ONE STATION. New Remote Batteries. Will Not CHG ch or VOLume
Unplug AC electrical cord for a bit then plug in and see if it resets.......................T.
Feb 12, 2008 | Televison & Video
Control Panel
Yes you can replace the chip, BUT, first try to clean the button contacts. I have to do that to my remotes, phones, and RCA TV (yes I have one too) etc.. around my house. Just needs a good cleaning. Don't forget to unplug the TV.
Jun 30, 2007 | RCA 32V550T 32" TV
Override Parental Control
Customer service at RCA stated that you have to simultaneously push the menu button on the TV and the volume down button on the factory issued remote hold for three seconds and the parental should unlock and allow access again.
Jun 29, 2007 | RCA F32645 32" TV
Channels keep changing
ok, let's try the simplest things first.... unplug the tv from the wall, and remove the batteries from the remote. wait about 5 or 10 minutes. reinstall the batteries and plug the tv back in. try it again. actually since you said you tried another remote, you can skip removing the batteries from the remote. if it still does it, try unplugging the tv overnight. if it still doesn't work right then, you have a processor problem, and need to have it looked at by a service tech.
Jul 07, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
