Question about BenQ FP737S-D 17" LCD Monitor
Wiress mixed up :(
My wires are mixed up, if the LCD is upside down on the left side there is 8 wires, 4 groups of 2 wires. 2blue and 2pink. how must it be pluged in?
  • 472 Answers
The wires your looking at are for the CCFL
They plug into power board on the same side they are on (the right looking from the front)
You may have a bit of silver paper covering where they connect so you cannot see it.
They feed up from between the screen and through holes that are near where the connectors are.
Be careful when plugging them in though, they only go in one way and forcing them will cause them to break.
Posted on Apr 09, 2008
Wiring diagram for mazda b2300 spark plus 8 spark plugs
  • from front of motor cylinder strait back 1234 ,fireing order 1342 this is right side /left side its 1342 numer 1 is first place to put a wire on the left on your coil pack or distribbuter and #1 is the last on the back. mazda-google- groups forum try this it wouldnt let me put down there hope it help guy
Nov 06, 2017 | Mazda Cars & Trucks
How do I fix an upside down and backwards touch screen on a Nintendo dsi
I suggest sending it back to Nintendo. They have an excellent technical group.
A thumbs up would be greatly appreciated if this answer is helpful to you.
Dec 14, 2014 | Nintendo Video Game Consoles & Games
Plays back on lcd screen upside down at times
When the viewport is completely flipped around so you can see it when you are looking at the lens, it automatically flips it upside down so it is right side up to the viewer. Make sure it is locked into the correct position to prevent this from happening.
Hope this helps
Dec 05, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
My laptops screen in up the wrong way, which button do i use to fix this? Thanks.
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Jul 27, 2011 | MSI A6200 Pentium Laptop Computer With...
Need to no how to replace spark plug wire
The firing order-------- 1-8-4-3-6-5-7-2
Looking at the engine from the front of car
plug #'s for left side, front to rear,1-3-5-7 #1 plug being the very first one.
plug #'s for right side, front to rear ---- 2-4-6-8.
May 21, 2010 | Chrysler Newport Cars & Trucks
I have a sony dcr-sr82 camcorder and the lcd upside down
It might be the flex wire connecting LCD with camcorder responsable. What happens when you turn the LCD on the other side?
Sep 23, 2009 | Video Cameras
I want to fit bigger hard drive to my ibm 380ed
Hard Drive Installation Instructions:
  • 1. Turn the notebook upside-down.
  • 2. Remove the battery pack.
  • 3. Remove the 8 Phillips screws on the bottom half of the notebook.
  • 4. Turn the notebook right-side-up.
  • 5. Raise the LCD.
  • 6. Remove the top half completely off of the notebook. Remove the 3 keyboard cables from the motherboard and set the top half of the notebook aside.
  • 7. Remove the top Phillips screw from behind the LCD right hinge.
  • 8. Remove the Phillips screw that is located above the parallel port.
  • 9. Remove the CD/Floppy disk and flip it out of the way (you don't have to remove its cables).
  • 10. Slide the hard drive out of the notebook.
  • 11. Remove the bracket from the old hard drive and install it onto the new hard drive.
  • 12. Slide the new hard drive into the notebook, making sure that it is firmly connected.
  • 13. Place the CD/Floppy disk back.
  • 14. Place back the Phillips screws that were removed in STEP# 9 and STEP# 8.
  • 15. Take the top half of the notebook and place back its 3 keybaord cables to the motherboard.
  • 16. Snap the top half of the notebook down and make sure that it is firmly in place.
  • 17. Close the LCD.
  • 18. Turn the notebook upside-down.
  • 19. Place back the 8 Phillips screws that were removed in STEP# 3.
  • 20. Place the battery pack back.
  • Enjoy!
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
    Jan 19, 2009 | IBM ThinkPad 380ED
    Fax not being sent
    Somehow, a group dial # has been set. Here is how to delete it:
    NOTE: Group Dial Numbers are entered using the One-Touch keypad on the left hand side of the WorkCentre. To change a Speed Dial that is within a Group Dial, the Group must be deleted first.
    1. Press the [Menu] button.
    2. On the left hand side of the Control Panel press the One-Touch [12] button.
    3. The LCD Display will read 'Select One-Touch for Group [01-20]'.
    4. Press the One-Touch key to be used for the Group Dial.
    5. One of two displays will appear:
      • If the Group Dial number has not been used:
        1. The LCD Display will read 'Group No: ### 1. YES 2. NO'.
        2. Using the Dialing Keypad press [1] to accept or
        3. Press [2] to return to step four.
        4. The LCD Display will read 'Enter One-Touch / Speed Dial> ##'.
        5. Continue with step 6.
      • If the Group Dial number has been used:
        1. The LCD Display will read 'Group ## Used 1: Renew 2: Other'.
        2. Using the Dialing Keypad press [1] to 'Renew'. This will cancel the Speed Dial or Group Dial entry and the Group Dial will be deleted.
        3. Press [2] to keep the current entry and select another Group Dial
        4. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
          Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Apr 26, 2008 | Xerox WorkCentre 470CX InkJet Printer
    TV will not Power Up / Blinking Green Light on Power Button
    May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
    1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
    2. Remove back cover
    3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
    4. Disconnect wire connector to side A/V at lower right side
    5. Disconnect wire connector to right side circuit Board
    6. Disconnect wire connector to left side circuit board
    7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
    8. Remove 3 screws each side of the metal box in the middle
    9. Fold back metal tape off bottom and top of metal box
    10. 1 wire connector at top of box I left connected
    11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
    12. On left side in box is power supply board
    13. Towards bottom of board you should see the numbers C2081 and C2074
    14. Remove the six screws holding down power supply board
    15. Flip board down towards bottom of Tv.
    16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
    17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
    18. Reassemble in reverse order and enjoy
    Nov 26, 2007 | Philips Magnavox 52MF437S/37 52 in. LCD TV
    LCD Television Proview RX326
    No better description then a picture! Can You post a few?
    Jul 07, 2017 | LG 42LP1D 42 in. LCD HDTV
    BenQ FP737S-D 17" LCD Monitor Logo
    24 people viewed this question
    Top BenQ Computers & Internet Experts
    Steve Allison
    Steve Allison
    Tommmix
    Level 1 Expert
    Computer Links
    Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
