Question about Frigidaire 30 in. Electric Single Self-Cleaning Wall Oven
I have a Frigidaire Electrolux wall oven, Model CGEB27S7CB1. The bottom oven stopped work but the top groil and fan still work. What to cope with this problem
No heat of the bottom (Bake) element when turn it on
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
  • 20 Answers
SOURCE: Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
Posted on May 29, 2009
  • 135 Answers
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
Posted on Aug 27, 2009
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
I have a Frigidaire Electrolux Model FEB30S5ABB. The oven will not heat up to the correct temperature and the bottom element is not turning on. We checked the element at it checks out ok. What could be...
Hello lizzyd62 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately.
Nov 23, 2012 | Frigidaire 30 in. Electric Single...
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
Replacing frigidaire wall oven door light/fan switch
Ask the Frigidaire Agent to go talk to a technician and get the answer to your problem. Technicians are available to the Agents. 1 (800) 374-4432
May 14, 2009 | Electrolux 30" Built-In Single Electric...
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
F 14 Error Message
well first it doesn't matter when the problem occurred warranty is warranty but you can pull the oven out and pull the panel off the top where the eoc is and pull the mylar ribbon out there is a black plastic piece at the base of the ribbon pull it up and pull the ribbon out clean it with a pencil eraser then reseat it and lock it down if that doesn't fix it then the eoc must be replaced go to www.frigidaire.com and find a service in your area it will be a warranty issue
Feb 09, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Frigidaire 30 in. Electric Single Self-Cleaning Wall Oven Logo
571 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
